New springs required (& Discs)
"M" Specific discussion
samZ4M
Post by samZ4M » Thu Jun 29, 2017 6:30 pm
So my M just failed it's MOT on rear spring broken and rear discs corroded.
If I do the 2 rear springs, it looks like it may be as cheap to fit Eibach all round. I'm not fussed about lowering, although the front could come down a bit. Is it an easy enough job, or are compressors etc required? Happy to get my hands dirty, just don't want to shell out for tools etc!
Thoughts?
Discs will be replaced with pads. Funny, as BMW passed it last year and they were worse! I had to go indi as the Oxford BMW is booking a month away!
OEM Part list:
34212282303 disc
34212282304 disc
34216761248 pads
34357836969 sensor
83192158851 paste
33507836827 spring
Angelus666
Post by Angelus666 » Thu Jun 29, 2017 6:40 pm
Fitting Eibachs all round is a good choice, but I think it's a two man job and can be tricky without the right tools. It'll cost you about £200 for the fitting at an independent.
samZ4M
Post by samZ4M » Thu Jun 29, 2017 6:47 pm
Thanks, what about just fitting rear OEM's, if there is still a similar cost, it makes sense to go Eibach still.
RedUn
Post by RedUn » Thu Jun 29, 2017 7:48 pm
Spring compressors are needed, they are about 15 quid though and we'll worth having. It's quite a simple job on the zed, just make sure to jack both sides up evenly makes it a lot easier with the arbs...
Give your self 45 mins a corner.
IMOLA Z4///MR
Mangozac
Post by Mangozac » Thu Jun 29, 2017 9:29 pm
RedUn wrote: Thu Jun 29, 2017 7:48 pm Spring compressors are needed, they are about 15 quid though and we'll worth having.
I would not want to place my life in the hands of 15 quid spring compressors!
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
Gazc
Post by Gazc » Thu Jun 29, 2017 9:39 pm
Why would you want to pay more for 2 lengths of stud bar and 4 shaped bits of metal. That's what I used to do mine no problems.
E92 M3 Silverstone blue
Z4MR Black Gone
Argenta
Post by Argenta » Thu Jun 29, 2017 9:39 pm
Easy peasy job, you only need compressors for the fronts.
RedUn
Post by RedUn » Thu Jun 29, 2017 11:12 pm
Mangozac wrote: Thu Jun 29, 2017 9:29 pm
If your that worried point the top mount at someone else when your undoing it :evil:
IMOLA Z4///MR
ferry
Post by ferry » Thu Jun 29, 2017 11:48 pm
I used H&R on my E46 M3 CS and had no complaints. Lasted much longer than OEM, slight drop for no big difference in ride quality.
I also swapped pads for RS29s. OEM parts were so expensive I usually fitted upgrades instead. RS29s were probably a bit OTT for the road but something like DS2500 might be worth a look.
D4dawg
Post by D4dawg » Thu Jun 29, 2017 11:51 pm
North Oxford did mine too
But as said they're down to 8 for 15 techs
3 weeks for Insp 1!!
Mangozac
Post by Mangozac » Fri Jun 30, 2017 8:27 am
RedUn wrote: Thu Jun 29, 2017 11:12 pm
Mangozac wrote: Thu Jun 29, 2017 9:29 pm I would not want to place my life in the hands of 15 quid spring compressors!
There are so many ways that parts can fly in all directions! Last time I had to do this a BMW tech mate did it for me using the dealership's big BMW spring compressor special tool and even with that it was evident how much force was involved!
samZ4M
Post by samZ4M » Fri Jun 30, 2017 8:36 am
Ahh, H&R, so what's the best ones to go for then? If it's of any help, I'm not fussed about lowering, but don't mind a bit either.
Marc, service and brake fluid booked for 25th July, 1 month from when I booked it! Useless.
abar121
Post by abar121 » Fri Jun 30, 2017 4:58 pm
Think about replacing the shocks too, unless they are relatively new. The Z4M is pretty hard on dampers anyway and fitting lowering springs is a quick way of highlighting any deficiencies.
'07 Z4M Interlagos Blue. All options except extended leather.
Dablk
Post by Dablk » Sat Jul 01, 2017 6:31 pm
Just had two new rear springs fitted. £320 all in.
| 07 Carbon Z4MC | Black Nappa | Carbon Leather |
| Oem 224 or CS Wheels In Anthracite | Loads of Toys | Iso Fix for Little One Days Out |
| 37K - June 17 |
tjlazer
Post by tjlazer » Sat Jul 01, 2017 7:48 pm
abar121 wrote: Fri Jun 30, 2017 4:58 pm Think about replacing the shocks too, unless they are relatively new. The Z4M is pretty hard on dampers anyway and fitting lowering springs is a quick way of highlighting any deficiencies.
I would have though the bilstein b12 kit is a cheaper and better option of that's the plan.
WAS: black on black MR with carbon trim. NOW: IB/Champagne/Carbon ZMC
