Exhaust. OEM?
"M" Specific discussion
slappywhite
Exhaust. OEM?
Post by slappywhite » Wed Jun 07, 2017 3:53 pm
Hi
My exhaust has started to blow a bit. It's quite loud on start up but calms down after it warms up but definitely needs replacing. Sounds like it's just one of the back boxes.
I think I want to stay OEM, it's a bit quiet but I don't fancy any drone at motorway speeds.
I'm not mad keen on going to BMW but equally not keen on somewhere like Kwik Fit.
Any suggestions?
cheers
Ducklakeview
Exhaust. OEM?
Post by Ducklakeview » Wed Jun 07, 2017 4:02 pm
OEM is stainless, and only available from BMW at EYE WATERING prices. Are you sure it's not just the clamps joining the back boxes to the system? Common failure as the clamps and bolts are NOT stainless, so rust away. Replacement clamps are less than £30 in stainless on Ebay..
Mike
slappywhite
Exhaust. OEM?
Post by slappywhite » Wed Jun 07, 2017 4:04 pm
So if it's stainless it won't have rotted? I went over a speed bump the other day and it definitely sounded like it went loose, very loud, then self corrected over the next speed bump. I can't look at it easily, it lives on the street , no access to a pit or a ramp.
mr wilks
Exhaust. OEM?
Post by mr wilks » Wed Jun 07, 2017 4:04 pm
Ducklakeview wrote: Wed Jun 07, 2017 4:02 pm OEM is stainless, and only available from BMW at EYE WATERING prices. Are you sure it's not just the clamps joining the back boxes to the system? Common failure as the clamps and bolts are NOT stainless, so rust away. Replacement clamps are less than £30 in stainless on Ebay..
Mike
Even more common is the corrosion of the internal "trumpet" flange where the clamp bolts the backbox to centre pipe , if that's gone the boxes are pretty much goosed :cry:
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
mr wilks
Exhaust. OEM?
Post by mr wilks » Wed Jun 07, 2017 4:06 pm
slappywhite wrote: Wed Jun 07, 2017 4:04 pm So if it's stainless it won't have rotted? I went over a speed bump the other day and it definitely sounded like it went loose, very loud, then self corrected over the next speed bump. I can't look at it easily, it lives on the street , no access to a pit or a ramp.
If you get it looked at & its worse case scenario i have a set of OEM boxes going :thumbsup:
viewtopic.php?f=7&t=92992
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
2dogs
Exhaust. OEM?
Post by 2dogs » Wed Jun 07, 2017 4:58 pm
This happen to me the clamp just rushed away :( it's an easy fix took me 30 mins or so :)
viewtopic.php?f=3&t=90165
Blue Z4MC - now gone
AlfaScozzesi
Exhaust. OEM?
Post by AlfaScozzesi » Wed Jun 07, 2017 6:36 pm
mr wilks wrote: Wed Jun 07, 2017 4:04 pm
Mike
If these flanges are corroded you can just get a welder to build them up again. When I got my bypass pipes put on and the back boxes needed to be removed the clamps had to be cut off and the trumpets needed a few runs of weld and then shaping to make good.
mr wilks
Exhaust. OEM?
Post by mr wilks » Wed Jun 07, 2017 7:06 pm
AlfaScozzesi wrote: Wed Jun 07, 2017 6:36 pm
Mike
I guess with the right skills anything can be refabricated , my last boxes i sold to a guy with badly corroded trumpets which even after attention continued to blow , if you have good chap on hand who won't have your pants down its always worth a try fixing first :thumbsup:
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
AlfaScozzesi
Exhaust. OEM?
Post by AlfaScozzesi » Wed Jun 07, 2017 7:12 pm
mr wilks wrote: Wed Jun 07, 2017 7:06 pm
It's true that the guy who did mine makes exhausts for all kinds of cars from scratch.
His welding is unreal and all his work is with stainless.
slappywhite
Exhaust. OEM?
Post by slappywhite » Thu Jun 08, 2017 8:28 am
mr wilks wrote: Wed Jun 07, 2017 4:06 pm
I hope I don't need them but thanks for the offer, I may have to take you up on that.
I'll get it looked at before anything falls off
dgm
Exhaust. OEM?
Post by dgm » Thu Jun 08, 2017 8:04 pm
Be prepared for the fluted ends of the x-pipe to be potentially cracked as well. I had to replace the back boxes and x-pipe when mine went.
06 Z4MC, Sapphire black, Aero sideskirts, BMW strutbrace, CSL's, Remus back boxes, Intravee and Alpine DAB
slappywhite
Exhaust. OEM?
Post by slappywhite » Wed Jun 28, 2017 12:18 pm
OK, I had it on a ramp, finally, there's a ring just ahead of the back boxes, holds two sections of pipe together, rotted away on both sides, leaving the sections hanging apart. The garage said they could do it but when I went back they said they couldn't get the part as it was BMW only. Does this look like the right part?
http://www.ebay.co.uk/itm/BMW-Genuine-E ... 1651380278
hard to find a diagram anywhere and I still don't want to go to BMW to be told I need a whole system.
Any help much appreciated.
Ducklakeview
Exhaust. OEM?
Post by Ducklakeview » Wed Jun 28, 2017 12:28 pm
Are you sure it's not the clamps that have gone, with you saying "both sides?" Replacements are available on Ebay.
http://www.ebay.co.uk/itm/BMW-E46-M3-Z3 ... SwHxVW69F2
Which part is it on RealOEM?
Mike
Fishy Dave
Exhaust. OEM?
Post by Fishy Dave » Wed Jun 28, 2017 12:31 pm
How about using something like this? http://www.ebay.co.uk/itm/M3-Z4M-STAINL ... 2543975872
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
Ducklakeview
Exhaust. OEM?
Post by Ducklakeview » Wed Jun 28, 2017 12:36 pm
THIS I6 kit comes with bothe the replacement clamps AND the rings.. http://www.ebay.co.uk/itm/BMW-E46-M3-Z4 ... 2286020882
Mike
