S54 Bearings changed today @ 107k....... Very worn shells content!
- hopz121
Hi all,
Had my Rod bearings changed on my 2004 E46 M3 today and thought i would share my thoughts as i know the Z4M shares the same engine and suffers similar issues!
I booked the car in to be done at my specialist as preventative maintenance as i knew it could be a potential issue and i didn't fancy ruining the bottom end of my engine.
I don't really know how well the car had been looked after before myself but in my ownership i have always warmed it up correctly and dropped the oil every 6k-7k and the car seems to have a pretty through service record.
Ill let the pictures do the talking....to say i was very lucky is an understatement!
Ash
E46 M3 Rob Bearings @ 107k by Ashley Hopson, on Flickr
Ash
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- GuidoK
I wonder if you'd plastigauge that worn one, how much the clearance is.
That way you can at least get a good idea of the wear, and how the clearance varies over the width.
For some reason really nobody does that or share that info.
- hopz121
No wear on the crank fortunatly
- bmwaddict
Interesting read hopz, especially as I'm about to purchase an s54 engined car with 107k on the clock! Had planned on getting it done immediately anyway just to be safe, but this has just confirmed that's a good idea! Thanks for sharing.
Currently zedless
'07 Mugello Blue Audi B7 RS4 Saloon with added goodies
'94 Black/Silver/Green Honda CBR400RR
Previous:
'07 Ruby Black Z4MC
'07 Sapphire Black Z4C 3.0si Sport
Previous:
'07 Ruby Black Z4MC
A timely intervention, you were lucky to get away with that one...it would not of lasted much longer before damaging the Crank!! I think seeing this I'm glad that I went down the oil analysis route.
2006 Monaco Blue Z4MC
Just in time, well done sir
07 Z4 M Coupe - Sapphire Black/Imola Red
Does anyone know why that one is so badly worn whereas the one on the opposite side is not too bad.
07 Z4MC standard spec
That's 107k miles, right? If so then it's not totally surprising to see them fairly worn.
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- hopz121
Yep miles.
I got the car at around 91k and have been bringing it up to my standard slowly over the last 16 months or so.
The next thing is the body work then I'll go and do a Vanos overhaul
- maxman
Which bearing is showing wear,the cap or the one from the con rod.Why the two colour indicators on the bearing.?
Oh my oh my...
Very lucky, they are amongst the worse I have seen that haven't spun or damaged the crank.
Lottery ticket this weekend,? Lol
- hopz121
Think I may have to get one now...... If I win ill be able to finish the M3 off which will be a bonus
I have seen a few worse than this, one did actually spin but otherwise not many, although not many seem to be actually changing them yet so I expect there is a lot of S54's in a similar state to this on the road!
I wouldn't go much past 100k by what I know now.
Gives me reassurance now though that they should be ok for another 100,000 miles though, ill also continue to chance the oil and 6-7k intervals.
It's painful driving it under 4000 RPM for a while though but it will be worth it in the end.
- hopz121
The ones with the most wear are the all the top half ones, the bottom half were not too bad as the photos show.
The upper bearing shell takes all the the loading, when the cylinder fires the force pushes the piston/conrod down onto the crankshaft thus loading the top bearing shell.
Dave.
- Fishy Dave
I'm past 50k now but am going to change them just in case as I'm sure the track use will have increased the wear, will post photos up once I start in a month or two. Still waiting on price back for parts from BMW.
Corvette C6
Mazda RX-8 race car
Now sold: Z4M Roadster, the best all round car I have owned.
Mazda RX-8 race car
