Split hose search advice
- Phil-E30
Afternoon all,
Going out to have a hunt for the issue causing my secondary air flow error code and acceleration hesitation.
I've checked that the black pump works on cold start, and it does, coming on after a few seconds. Therefore I want to check for split hoses and vacuum leaks.
It'd be great if anyone had any suggestions on which hoses to check as good starting points. Just tell me where they are in the engine bay and I'll have a good look!
"If you even dream of beating me you'd better wake up and apologise."
Muhammad Ali
Muhammad Ali
- Chris_D
take iit you alreadychecked for the main air intake manifold from the air box right through to the throttle body?
that hose part from the MAF to the TB is notorious for splitting at the Y section.....
- TomK
Chris_D wrote:take iit you alreadychecked for the main air intake manifold from the air box right through to the throttle body?
Not like that on the S54 Chris.
Phil,
There's only one pipe really from the secondary air pump (circled in blue), so obviously check that. It's been some time since I've fiddled with it but from recollection it connects to a valve (circled in red). Pull it off from there and check the pump is actually doing anything would be my first starting point. What is the acceleration hesitation you are referring to? When cold, all the time, etc?
- Phil-E30
Thanks Tom, I'll take that hose off and check the pump is doing its job. I also wondered if the valve may be faulty but was unsure how I'd know if this was the case. I really need to get the BMW diagnostic software for the car laptop.
As for the acceleration hesitation, it's pretty much all the time. I plant my foot, it takes a couple of seconds to react and then I can feel the car come to life. It's possibly more pronounced when cold.
Only error codes I've got from my generic reader point to secondary air system.
Muhammad Ali
Muhammad Ali
- TomK
Phil-E30 wrote:Thanks Tom, I'll take that hose off and check the pump is doing its job. I also wondered if the valve may be faulty but was unsure how I'd know if this was the case. I really need to get the BMW diagnostic software for the car laptop.
Hmmm, that's pretty odd. Not really heard of that symptom before, sounds quite severe .
Secondary air pump does nothing after a couple of minutes really so perhaps it's a red herring
I think you can check if the valve is working or not by blowing through the hole (where the secondary air pump would blow through) on cold start up, from recollection it alters the revs but I've had a couple of beers and may not be thinking straight
- TomK
This explains it all better Phil... It could be that the check valve has gone bad leaving it open all the time?
http://www.bavauto.com/newsletter/2008_ ... pdf#page=6
A hose had split on my z4 causing air ingress it was the small rubber one at the back on the intake side.
- BMWZ4MC
Mine too, with consequent misfire.goon wrote:A hose had split on my z4 causing air ingress it was the small rubber one at the back on the intake side.
S2000 GT - gone
- Phil-E30
Thanks Tom, that's really useful actually. I will do a bit of diagnostics today if I have time. I also need to try and get the BMW diag software downloaded. I hope you enjoyed the beers last nightTomK wrote:This explains it all better Phil... It could be that the check valve has gone bad leaving it open all the time?
Cheers Goon & Z4MC, I will double check a few more hoses. I did a quick check spraying water onto potentially problematic hoses yesterday and didn't find anything alarming.
Muhammad Ali
Muhammad Ali
- Phil-E30
Z4MC & Goon, on the above image that Tom posted, where was the hose that you had split?BMWZ4MC wrote:Mine too, with consequent misfire.goon wrote:A hose had split on my z4 causing air ingress it was the small rubber one at the back on the intake side.
Muhammad Ali
Muhammad Ali
at the very back of the right intake manifold, it cant be seen on that photo.
- BMWZ4MC
What he said
S2000 GT - gone
