In my 2005 E46 M3 whenever my wife or I use our key it automatically knows our seat position when you unlock, which is very useful indeed. I've never had it coded in or anything.
However our 2007 z4mc does not do this. So I assume it must be possible, but how do you do it??
Memory seats from key??
It just needs turning on in SSS. Carly may also do it?
I do have the cable-shack cable and software, but I have no idea how to use it
- sk93
If you can get the SSS virtual machine to turn on and boot up, and detect the cable is plugged into the car, the hard bit is done.
If you're in that state, I can guide you to the option in question.
Tho, this is also possible with NCSExpert (NCSDummy ftw!) if you've got that up and connected
Thank you, I expect I will take you up on that kind offer.sk93 wrote:If you can get the SSS virtual machine to turn on and boot up, and detect the cable is plugged into the car, the hard bit is done.
I don't recall seeing any SSS software but I do have both NCS
don't need SSS , all can be done in ncsexpert
