Daft oil change question
"M" Specific discussion
mj2k
Re: Daft oil change question
Post by mj2k » Mon Sep 07, 2015 9:11 pm
Scooba_Steve wrote:
pvr wrote:Will this be the first outing of the jack then? ;)
If it is - good lad, DIY is the mark of a loving owner :thumbsup:
Tips (excuse teaching to suck eggs):
Don't rush
Don't get squashed
For an oil change I jack up onto ramps one side at a time. If I'm honest you can probably get away with just doing one side, though I found some 'wiggling' was needed each side to get the last little bit out.
Don't get a 14L pan like I did... you can't lower the car onto it! :headbang:
I was just going to jack the front, good call on both sides.
Think I was going to go large on the pan, just to be safe - great insight :thumbsup:
First time ever changing oil, always paid before...just hope I don't get any leaks, an expensive mistake on this engine if I get it wrong!
And yes, first jack usage too - chickened out before trying to clear the drains as the light gravel in the Tarmac kept making the jack jerk & basically got nervous - will man up & also put the jack on some ply so it moves smoothly on its wheels.
2016 F82 M4 Comp Pack, Mineral White
2016 F56 JCW - GONE
2007 ZMR, Titanium Silver for sunny days
2012 N18 JCW - GONE
2007 3.0si Z4C, Stratus Grey, Amarone Leather - GONE
2013 520d F10 - GONE
mj2k
Post by mj2k » Mon Sep 07, 2015 9:13 pm
Don't rush
Don't get squashed
Do make a will - leave everything to PVR
Corrected that for you :thumbsup:
:rofl:
2016 F56 JCW - GONE
2012 N18 JCW - GONE
Scooba_Steve
Post by Scooba_Steve » Mon Sep 07, 2015 9:32 pm
:lol:
You can use the front centre (I don't have that luxury) but I think you might find it lifts a little higher at the sides due to the jacking point covers. I can only just about lift onto ramps.
pvr
Post by pvr » Mon Sep 07, 2015 9:34 pm
The front jack point is great to be able to add the axel stands though on both sides at the same time.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
mj2k
Post by mj2k » Mon Sep 07, 2015 9:35 pm
Scooba_Steve wrote::lol:
Will let you know how I get on, in theory it seems very simple & that's the concern :!:
2016 F56 JCW - GONE
2012 N18 JCW - GONE
srhutch
Moderator
Moderator
Post by srhutch » Mon Sep 07, 2015 9:42 pm
abar121 wrote:In most cars (and motorcycles come to that), I would be happy using cheaper fully synthetic oils. I've used the Halfords fully synthetic oils in many vehicles and never had a problem. They are usually produced by comma (an Exxon / Mobil company) and can be ridiculously cheap, especially with a trade card.
On the S54, I stick with the recommended Castrol TWS oil, given that it was developed with the factory M engineers at the time when the earlier issues that the motor had in the E46 M3, were prevalent. Given the unique complexities of the M diff, I would also stick to their recommendation on this.
But it's a personal choice. Others swear by Redline products, or oils with more zinc in them. I don't really have enough experience so will take the easy option and put my faith in BMWs engineers on this one.
On a car that's regularly tracked or putting out significantly more power, I would deffo change the oil on a more regular basis.
You will be swapping to Shell Oils now then. :wink:
http://www.shell.com/global/products-se ... plier.html
goon
Post by goon » Tue Sep 08, 2015 5:28 pm
pvr wrote:Never heard of Millers :oops:
Seriously? When I was on holiday in the States I drank gallons of Millers draught! :)
mr wilks
Post by mr wilks » Tue Sep 08, 2015 5:37 pm
Haha , PVR probably hasn't heard of that Millers either :P
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
mj2k
Post by mj2k » Wed Oct 14, 2015 12:20 pm
I am assuming this is fine for an oil pan?
http://www.eurocarparts.com/ecp/c/BMW_Z ... 2&0&t5_549
Large enough to hold the 5.5L but small enough to lower the car over.
Having read the E89 oil change woes, I have a building concern about this. Due to do it in another 600 miles, so finally getting around to ordering the bits. So far: Mann Oil Filter with all the washers, 6L of Edge 10W60, just the oil pan left I believe?
Aside from checking I have all the right sockets before starting that is!
2016 F56 JCW - GONE
2012 N18 JCW - GONE
CornishRob
Post by CornishRob » Wed Oct 14, 2015 12:39 pm
Something like this might help get your head around it. Havent check to see if the procedure is correct though
http://www.billswebspace.com/Z4MS54OilChange.htm
Current: 2007 Titanium Silver Z4MC - For Sale End of Feb
Previous: 2002 Land Rover Defender 90
mj2k
Post by mj2k » Wed Oct 14, 2015 1:17 pm
CornishRob wrote:Something like this might help get your head around it. Havent check to see if the procedure is correct though
:thumbsup: Makes perfect sense
2016 F56 JCW - GONE
2012 N18 JCW - GONE
Adam D
Post by Adam D » Fri Oct 16, 2015 10:45 pm
I use a pela 6.5 litre suction pump to change the oil at mid service interval; its usually fairly black by then anyway. Always used castrol tws/edge but open minded to other oils if others find them beneficial.
Silver Grey 2007 Z4MR which needs to be driven more :evil: :P :cool: :D :thumbsup:
mj2k
Post by mj2k » Sat Oct 17, 2015 3:42 pm
Adam D wrote:I use a pela 6.5 litre suction pump to change the oil at mid service interval; its usually fairly black by then anyway. Always used castrol tws/edge but open minded to other oils if others find them beneficial.
The pela seems another £30 more than this
http://www.amazon.co.uk/Extraction-Tran ... R160%2C160_
Wondering if it is worth the extra.
Seems far easier than going underneath the car, suddenly feeling the lazier approach is ideal :P
How much of the 5.5L do you get out?
2016 F56 JCW - GONE
2012 N18 JCW - GONE
biggeoff
Post by biggeoff » Sat Oct 17, 2015 4:53 pm
I with Steve on this as an ex motor mechanic I change mine every 5 thou
Mike6
Post by Mike6 » Sat Oct 17, 2015 5:31 pm
I have the E85 so procedure may be different but very easy on my car simply jacking up the drivers side, using an axle stand for piece of mind, dropping the cover then unbolting the sump plug. Personally I would never use one of those suction devices as oil crud, bits of swarf etc are all intended to drop into the lower sump recesses and will only flush out doing the job properly.
