Loud tappet like noises from Engine....
"M" Specific discussion
BMWZ4MC
Post by BMWZ4MC » Mon Oct 23, 2017 9:02 pm
T1berious wrote: Mon Oct 23, 2017 3:30 pm Well, to the guys who said it wasn't bottom end...
You were right!
Big ends replaced and noise remains. Engine now going to be removed and stripped.
Ouch!
That’s ridiculous. I’d recover the car to a capable ///M specialist.
I think you should open negotiations with your current garage by refusing to pay since they’ve not fixed the problem. Ultimately, paying 50% of the cost to change the bearing shells would be reasonable as it’s preventative maintenance anyway.
Give Phil a call if you’re not too far away:
BMWZ4MC wrote: Sat Oct 14, 2017 12:30 pm I'm in the followers / cams camp. The good news is that the primary failure seems to be the case hardening on the followers, so catching it early and not driving further avoids damage to the cams. If that is the cause, Schrick sell OEM followers to which they apply an additional hardening process. They aren't terribly expensive although I would replace them all. If you need news cams, they are pretty costly and the labour required increases significantly due to the limited access in the Z4M (cf the E46 M3). The job can be done without dismantling the entire front of the car but only by someone who knows what they're doing.
Where are you based? Phil at CPC in Amersham has done this job on several forum cars and many M3s.
S2000 GT - gone
john-e89
Post by john-e89 » Mon Oct 23, 2017 10:15 pm
Not a nice read at all.
MR2 MK 2
E89 35is
G29
T1berious
Post by T1berious » Tue Oct 24, 2017 8:01 am
I think I'm going to call him and ask if he's inspected the valve train.
The whole misdiagnosis thing is a concern but I'm kind of in the preventative maintenance is a good thing boat. Also when the car goes wrong I normally just take it BMW and assume the position. However this time I felt that the saving would be worth it as it was looking like 700-1000.
Now, I'm no so sure....
I'm at the point where I just want it fixed.
Anyone you guys recommend in the Midlands area who can inspect it post repair?
T1b
Current
718 Cayman GTS 4.0, Kia EV6 GT line S
F87 M2C ,F82 440i, E85 Z4MR, E92 330i All Gone!
Monkeydonkeyratmagic
Post by Monkeydonkeyratmagic » Tue Oct 24, 2017 8:40 am
Doesn't sound internal to me, more like something like a Mani bolt worked it's way loose or a pulley knocking. Does not sound like death rattle at all not metallic enough.
MR-2 Turbo Rev2
Yep no Z yet. On the hunt.
T1berious
Post by T1berious » Tue Oct 24, 2017 11:11 am
Mani bolt?
Current
Online
mmm-five
Post by mmm-five » Tue Oct 24, 2017 11:23 am
T1berious wrote: Tue Oct 24, 2017 11:11 amMani bolt?
I assume it’s short for the exhaust manifold bolt. Although I’ve never seen an issue with one coming loose, normally quite the opposite.
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
T1berious
Post by T1berious » Tue Oct 24, 2017 11:54 am
Cheers :)
Current
jimmybell
Post by jimmybell » Tue Oct 24, 2017 3:05 pm
+1 for CPC in Amersham, appreciate might not be anywhere nearby but they did the full works on my car solving follower finger wear (and were capable of identifying it very easily).
I'd aim to find someone who has history of investigating this issue in order to confirm/rule it out.
JB
V12 Vantage S - Hammerhead Silver, Manual, Lightweight Wheels, Exterior Carbon++, Carbon Buckets, AMR Performance Pack.
M135i LCI - ZF8, White, HK Audio, Adaptive
GONE Z4 M Coupe, Imola, CSLs
GONE C63 AMG, Black, Performance Pack+, LSD, HK
T1berious
Post by T1berious » Fri Oct 27, 2017 8:22 am
I'm kind of in the boat I'm in and am adopting the "preventative maintenance" approach to the work being done. Turns out there was a bit of metal in cylinder 4 (how it wasn't destroyed and flushed out the exhaust I have no idea).
But engine in pieces
Hopefully will be back soon, fighting fit and ready for a Dyno session
Current
Ewazix
Post by Ewazix » Fri Oct 27, 2017 9:11 am
Where did the metal come from?
I've had similar on one of my other cars caused by a fragment of the plug tip ceramic (actually it was caused by a moronic main dealer tech damaging the old plug on removal, but that's off topic) anyway like yours that one wasn't expelled messing-up the piston and scoring the bore :cry:
2018 Cooper S Countryman
Fiesta Ecoboost
Beedub
Post by Beedub » Fri Oct 27, 2017 9:36 am
the plugs look in terrible shape....... :!: :!: :!: :!:
T1berious
Post by T1berious » Fri Oct 27, 2017 9:40 am
I don't think it was the cause of the issue, but hey we'll see what else he finds. I'll keep you posted
Current
Mangozac
Post by Mangozac » Fri Oct 27, 2017 10:26 am
Beedub wrote: Fri Oct 27, 2017 9:36 am the plugs look in terrible shape....... :!: :!: :!: :!:
The whole lot looks in poorer shape than I'd have expected. How many miles was it?
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
T1berious
Post by T1berious » Fri Oct 27, 2017 11:31 am
91K
Current
T1berious
Post by T1berious » Fri Oct 27, 2017 11:51 am
The question has to be why would it be so bad?
Current
