5W30 in stead of 10W60
"M" Specific discussion
Rene_Z4MC
Post by Rene_Z4MC » Wed Oct 04, 2017 7:52 pm
I just got my M back from an oil service and see 5.5liter of Castrol 5W30 on the receipt.
This should be 10W60 right? :o
I will of course phone them about it tomorrow but I guess they will say that its a typo and they have put the right oil in...
What do you guys think, whats the best approach here? Also can I check which oil is in and can 5W30 be harmfull??
Any advice is welcome.
2006 Z4M Coupe Interlagos Blue, CS Wheels with Michelin PSS, Eibach, CDV delete, RTAB limiters, Vibra Technics Engine Mounts, OEM Strutbrace, ZHP gear knob
mr wilks
Post by mr wilks » Wed Oct 04, 2017 7:54 pm
Id only be happy with another oil change elsewhere making sure 10w 60 went in :cry: just not worth the risk :(
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
Ducklakeview
Post by Ducklakeview » Wed Oct 04, 2017 7:56 pm
Like Mr Wilks said.. There is a BIG difference between the two..
Mike
RedUn
Post by RedUn » Wed Oct 04, 2017 8:22 pm
I wouldn't even drive it... Not worth the risk
IMOLA Z4///MR
Havard
Post by Havard » Wed Oct 04, 2017 8:42 pm
That is a pretty major mistake if they have put 5w30 in.
I hope it is a misprint and they can prove it.
D4dawg
Post by D4dawg » Wed Oct 04, 2017 8:55 pm
As others
Screw that !!
5w may help when cold as it's thinner but then it will be pushed around engine differently
But 30 is half of the thickness of 60 at running temp so will not protect nor pump round to lube engine properly !!
Don't drive it
Demand it lifted and full oil and filter change
Rene_Z4MC
Post by Rene_Z4MC » Wed Oct 04, 2017 9:28 pm
Thanks for the replies guys :thumbsup:
Mangozac
Post by Mangozac » Wed Oct 04, 2017 9:33 pm
The Castrol Edge Professional 10W60 has a UV fluorescent dye in it, so that's one way to check (if they were supposed to use "proper" TWS).
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
Ducklakeview
Post by Ducklakeview » Wed Oct 04, 2017 9:35 pm
Main dealer or indy?
Mike
Rene_Z4MC
Post by Rene_Z4MC » Wed Oct 04, 2017 10:06 pm
Ducklakeview wrote: Wed Oct 04, 2017 9:35 pm Main dealer or indy?
Mike
Not a genuine dealer, it was at a BMW Specialist (so BMW only indy?)
Ducklakeview
Post by Ducklakeview » Wed Oct 04, 2017 10:10 pm
Rene_Z4MC wrote: Wed Oct 04, 2017 10:06 pm
Mike
Well they should know the risks of letting it be driven with the wrong oil in it. Hopefully it was a typo, BUT how can they prove it?
This could turn into a he said/she said with the indy - Did you by chance pay for any part of the work with a credit card?
Mike
mcbeee
Post by mcbeee » Thu Oct 05, 2017 12:48 am
My mechanic/ golf buddy told me a while back that not using TWS can be catastrophic to the S54. I’d get it out .... maybe jack it up and drain then refill with correct oil . The filter amount should be negligible .
Sold the Z4 M Roadster and a 911 Carrera S now I have a 2021 Z4 3.0i
8) 8) 8)
mmm-five
Post by mmm-five » Thu Oct 05, 2017 9:11 am
mcbeee wrote: Thu Oct 05, 2017 12:48 am My mechanic/ golf buddy told me a while back that not using TWS can be catastrophic to the S54. I’d get it out .... maybe jack it up and drain then refill with correct oil . The filter amount should be negligible .
I assume he must be including Castrol Edge in that prescription, as that's the 'consumer' name for TWS...which is a BMW-specific name for their dealer-supplier RS/Edge (depending on the year).
Be careful of using the 'Edge Sport' variant though, as it has a lower shear strength than the original RS/TWS/Edge.
Had many of these ‘best oil discussions' on the M5 Board too :P
Trigger’s Z4MC
Some bits now over 163,000 miles, some less than 1,000 miles.
Individual Ruby Black, Individual extended champagne leather, plus many options
Rene_Z4MC
Post by Rene_Z4MC » Thu Oct 05, 2017 9:20 am
Update:
Phoned them this morning and talked to the owner of the place, before stating my worries I casually asked what kind of oil they put in and he replied 10W60 straight away, without hesitation. He is a good guy and they have done good work on my car in previous years so I think I can trust him. After that I asked why it states 5W30 on the receipt and he knew it must be a mistake from the administration girl. He then again stated that he was absolutely 100% sure that the right oil was put in because he was involved in the job himself, he knew the details.
Also Yesterday I placed a bunch of drops of oil from the engine and some drops of fresh 10W60 from the bottle on a sheet of aluminium and put the sheet at an angle. Both the engine oil and the fresh oil showed very similar 'dripping speed' which makes me believe that the viscosity is the same.
All in all I think I'm good, again thanks for the advice guys :thumbsup:
Rene_Z4MC
Post by Rene_Z4MC » Thu Oct 05, 2017 9:26 am
Mangozac wrote: Wed Oct 04, 2017 9:33 pm The Castrol Edge Professional 10W60 has a UV fluorescent dye in it, so that's one way to check (if they were supposed to use "proper" TWS).
The datasheet does indeed state it has 'signature fluorescent colour' but I was not able to observe any 'glowing' when putting it in UV light (tanning lamp), however my own fresh bottle of Castrol 10W60 also didn't show any glowing so I'm not sure if that is really a feature.
