Proud new owner of this...
- MrPT
Even with just the rear tyres changed it is much better than what I had before (275/30) on B roads and over expansion gaps etc. When moving to 19s I put the suspension to nearly full soft and the ride was acceptable, but still not compliant enough to handle sudden, small changes in the road surface. An 8cm sidewall is silly, in hindsight, but I wanted to keep the look of the 19s instead of moving to 18s.
Going to change the fronts soon too. It looks a bit odd, currently, but the main issue is the large difference between front/rear rolling radius, which could be affecting the DSC. Since I dropped the front to match the reduced arch gap at the rear, the car is also raked forward enough now that I've had to be more careful on speed bumps etc.
I'm not sure you will be able to do 235/40 and 265/35 without height-adjustable suspension, but 225/40 and 255/35 apparently works well. 245/35 and 265/35 might rub a little, but also looks like a good combination to go for since you have the added bonus of it reducing the factory stagger (helps remove understeer).
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Beedub
i run 18s on semi slick 235/40sF 265/35s R
Performance from this setup is fantastic, haven't noticed any more intervention with the DSC tbh but these have been on for a while.. Traction until warm can be limited , no rubbing at full compression, car is lowered only around 10mm from stock as you can see very conservative i can fit my hand right into the wheel arch , i wanted as much compliance as possible from the track based suspension setup, which mean travel needed to be retained, The tyre size give a lovely fat sidewall, which imo really suits the short and squat look of the z4M
From my experience this car behaves best on 18s, do lots of research before making your wheel choice.
- fullsizeoutput_54c.jpeg (288.53 KiB) Viewed 1875 times
- Beedub
Front ,
- fullsizeoutput_577.jpeg (360.11 KiB) Viewed 1873 times
Thank you for that! Some useful info there!MrPT wrote: ↑Sat Sep 16, 2017 2:33 pmEven with just the rear tyres changed it is much better than what I had before (275/30) on B roads and over expansion gaps etc. When moving to 19s I put the suspension to nearly full soft and the ride was acceptable, but still not compliant enough to handle sudden, small changes in the road surface. An 8cm sidewall is silly, in hindsight, but I wanted to keep the look of the 19s instead of moving to 18s.
Car looks lovely. What suspension set up here you running?
I've not seen them wheels on a Z4M before - what are they?Beedub wrote: ↑Sat Sep 16, 2017 3:50 pm i run 18s on semi slick 235/40sF 265/35s R
I do agree - I did think 18s look better on a Z4M. But after seeing some lovely examples with 19s on I'm 50:50.
I don't want to break the bank either - 19" CSL Reps are pretty easy to come buy for a decent price. With most other stuff it seems to be £1k+. I guess the alternative is to leave it on the wheels its on with maybe a powder coat.
- Beedub
These are the rare cromodora 260M 18" stock wheel the originally came on the e92 m3Sohailnisar wrote: ↑Sat Sep 16, 2017 5:42 pmI've not seen them wheels on a Z4M before - what are they?Beedub wrote: ↑Sat Sep 16, 2017 3:50 pm i run 18s on semi slick 235/40sF 265/35s R
- MrPT
Thanks. It's on KW V3s - quite popular on here. Rear is at stock height; front dropped 24mm at the moment!Sohailnisar wrote: ↑Sat Sep 16, 2017 5:38 pmCar looks lovely. What suspension set up here you running?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Beedub
Kw's really are the business, supplied stuff on both generations of the GTS models too.... albeit in clubsport spec.MrPT wrote: ↑Sat Sep 16, 2017 7:56 pmThanks. It's on KW V3s - quite popular on here. Rear is at stock height; front dropped 24mm at the moment!Sohailnisar wrote: ↑Sat Sep 16, 2017 5:38 pmCar looks lovely. What suspension set up here you running?
Please excuse the dirt on the car, but first mod done...
Looks much better now. Hopefully better pictures to follow once it's been washed and waxed.
So I've been driving this for around a week now, here's some first thoughts:
In my S2000 I was very careful to not VTEC when cold, so to be safe I'd keep revs below 4k when cold.
I've noticed the amber lights that move up the rev range as the car gets warmer. What do people keep the revs at when cold?
At what point do people think it's safe to give it the beans?
I'm hyper aware of any sounds on my cars, so couple of queries:
- It takes a long time to warm up!
- The gearbox takes a little getting used to
- It's not that harsh!
- The engine!
- When changing from 1st to 2nd (to a lesser extent shifting up the other gears) - there's a bit of a 'wobble' when I engage the clutch to shift gear, I can't feel anything it's just that I can hear a wobble
- If I sit around 3.5k revs - it sounds like crackling - I know the S54 is a noisy engine - so my guess is that's just what it sounds like?
- MrPT
Really interesting to hear your thoughts. S2000 has a pretty cool engine too.
It does take a while to warm up, yep. Consensus seems to be that you should stick below 3k until the oil is up up temp at around 80-85C.
Gearbox is stiff - comparisons with the Honda usually aren't that flattering! 1st to 2nd needs to be either super gentle or super punchy. Anything in the middle tends to be a bit jerky.
3.5k could be Vanos rattling, although that's usually a little lower in the range. It's a horrible, gravelly metallic sound but is harmless. There was a service bulletin about it - SI B 11 05 06.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
Thank you MrPTMrPT wrote: ↑Tue Sep 19, 2017 12:03 am Really interesting to hear your thoughts. S2000 has a pretty cool engine too.
Did a bit of quick research, few people have mentioned it on M3cutters too, seems like it's just what the S54 sounds like.
Got my oil analysis back. Looks like a clean bill of health to me...
- RedUn
Remove the cdv, just like on the S2000. Helps a lot with the gear change
Ex S2000 owner
Ex S2000 owner
IMOLA Z4///MR
