Numerous BMW Badges
- IAmOrion
Numerous BMW Badges
I have some BMW Badges that I no longer need. Can be sold as sets, or sold separately. All prices INCLUDE POSTAGE
1st up are these 82mm Badges. I have 4 available. Never been used, has black sticky foam on the back, and a protective film on the front.
SOLD
2 x 68mm Wheel Center Caps with badges. These are as new, never used. £8 for the pair
USED Black & White Carbon Fibre Set: 3 x 82mm (2 side roundels + boot), 4 x 68mm wheel center caps, 74mm (Bonnet), and a Steering Wheel badge. The steering wheel badge has lost its backing and is sticky hence why it's in a bag. £15
One of the center caps was slightly scuffed/scratched from removal, the remaining 3 are IMO pretty much perfect.
(with flash)
(without flash)
As always, welcome to send offers.
SOLD
(with flash)
(without flash)
- IMG_0195.jpg (244.29 KiB) Viewed 1080 times
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
Numerous BMW Badges
Remind me again, Are the 82mm badges for the e85 bonnet? I forgot their weird size! If so I’ll take oneIAmOrion wrote: ↑Sat Dec 02, 2017 5:01 pm I have some BMW Badges that I no longer need. Can be sold as sets, or sold separately. All prices INCLUDE POSTAGE
£6 each / offers
USED Black & White Carbon Fibre Set: 3 x 82mm (2 side roundels + boot), 4 x 68mm wheel center caps, 72mm (Bonnet), and a Steering Wheel badge. The steering wheel badge has lost its backing and is sticky hence why it's in a bag. £15
(with flash)
(without flash)
Z4 now sold
Current - M235i
Current - M235i
- IAmOrion
Numerous BMW Badges
Well, MY E85 was 72/74mm from memory. The 82mm fits the BOOT but is too big for the bonnet. Not sure if that just the pre facelift (Mine's 2003) so I can't give a definite answer... maybe someone with greater knowledge may chip in with sizes
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- TomK
Numerous BMW Badges
£20 for the four ok? I'll drop you a pm, thanks.
- IAmOrion
Numerous BMW Badges
Accepted, and replied.
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- David
Numerous BMW Badges
Edit - Sorry! Just researched and it appears the bonnet badge is meant to be 70mm, so I’ll have to pass!
Regards,
David
- IAmOrion
Numerous BMW Badges
No problem. Yes I would’ve taken £10, I’ll measure the bonnet badge shortly and get back to you just in case I got the size wrong. What model is yours? These were fitted perfectly to my 2003 pre facelift
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- David
Numerous BMW Badges
Mine’s a 2006 (Facelift) 3.0si.
https://rover.ebay.com/rover/0/0/0?mpre ... 0946799495
As you can see from here, OEM size is 70mm
- IAmOrion
Numerous BMW Badges
You're absolutely correct. I just realise I never stated that the bonnet badge does NOT have the backing mount piece, so it's just the badge. I've just measured it and the badge itself is 66.5mm +/- a fraction due a to manual measurement with verniers. So that's the right size to fit the 70mm bonnet backing mount. But might be no good to you without that backing plate unless you fancy peeling off the OEM badge and sticking this one in its place.David wrote: ↑Mon Dec 04, 2017 9:37 am Mine’s a 2006 (Facelift) 3.0si.
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- David
Numerous BMW Badges
Too fiddly for me, but thank you for taking the time to find that out. GLWTSIAmOrion wrote: ↑Mon Dec 04, 2017 9:43 amYou're absolutely correct. I just realise I never stated that the bonnet badge does NOT have the backing mount piece, so it's just the badge. I've just measured it and the badge itself is 66.5mm +/- a fraction due a to manual measurement with verniers. So that's the right size to fit the 70mm bonnet backing mount. But might be no good to you without that backing plate unless you fancy peeling off the OEM badge and sticking this one in its place.David wrote: ↑Mon Dec 04, 2017 9:37 am Mine’s a 2006 (Facelift) 3.0si.
David
