Koenigsegg Freevalve - camless engine
- Ducklakeview
- Smartbear
I think lotus have been playing around with camless engines for yonks, they had a running engine but I don't think it had a very high rpm range?
e85 3.0si sold
- Nictrix
Shame that you would need to rely on electronics to make sure the engine didnt go bang after the valves hit the pistons.
At least with a normal engine there needs to be a failure like a belt or chain snapping for damage to occur.
I think the best idea for an engine was an old Honda design with gear driven cams. I think Aprilia have also done this in recent years.
- Ethicsgradient
Nictrix wrote: ↑Mon Aug 07, 2017 7:16 pm Shame that you would need to rely on electronics to make sure the engine didnt go bang after the valves hit the pistons.
Ford 2.3 and 2.8 V6 Cologne engine was gear driven I think . Hondas 750 VFR engine was definatley gear driven , thats what the interesting whine noise they made was .
- Nictrix
They would have been quite a bit before the Honda engines then, Im sure the VFRs first had it in the mid 80s.Ethicsgradient wrote: ↑Tue Aug 08, 2017 8:08 pmNictrix wrote: ↑Mon Aug 07, 2017 7:16 pm Shame that you would need to rely on electronics to make sure the engine didnt go bang after the valves hit the pistons.
Aprilia put gear driven cams in their WSB bikes trying to bend the rules a little as they gave more power. They had to release a kit to change the normal engines to gear driven to stay withing the rules, even though probably nobody would buy the kit.
Onlinebuzyg
- Ducklakeview
The Ford cologne had a camshaft drive gear made from FIBRE, running in oil.. I kid you not! They used to just break into pieces...
Mike
Mike
- maxman
I remember when I worked in a garage in the 70's,we had a V6 ford in with a misfire and after a lot of digging it was found the outer part of the fibre gear was slipping backwards and forwards,leading us a merry dance.Ducklakeview wrote: ↑Tue Aug 08, 2017 8:52 pm The Ford cologne had a camshaft drive gear made from FIBRE, running in oil.. I kid you not! They used to just break into pieces...
Mike
- Ethicsgradient
Nictrix wrote: ↑Tue Aug 08, 2017 8:16 pmThey would have been quite a bit before the Honda engines then, Im sure the VFRs first had it in the mid 80s.Ethicsgradient wrote: ↑Tue Aug 08, 2017 8:08 pmNictrix wrote: ↑Mon Aug 07, 2017 7:16 pm Shame that you would need to rely on electronics to make sure the engine didnt go bang after the valves hit the pistons.
Nice bikes Aprillia , Had a SL1000 Falco some years ago , as a sport touring miles muncher it was great .
- Ethicsgradient
I went for a look because it was a foggy memory of them , seems there was a conversion kit to make the gears not fiber and proper metalDucklakeview wrote: ↑Tue Aug 08, 2017 8:52 pm The Ford cologne had a camshaft drive gear made from FIBRE, running in oil.. I kid you not! They used to just break into pieces...
Mike
- Flyingfifer
Cool tech, its about time we removed belts and stuff from the engine bays and with upwards of 50% increases to both torque and power its exciting stuff not to mention the lower profile of the engine (lowering the centre of gravity) and substantially lower weight!Freevalve wrote: What happens if there is a catastrophic failure on a Freevalve equipped engine compared to a camshaft equipped engine?
If the complete system fails, the engine will simply stop running with no damage to the engine, as compared to a camshaft equipped engine which will be badly damaged or destroyed if a belt or chain breaks.
...The engine will be able to provide limp-home capability even if 75% of the actuators were to fail.
2006 3.0Si Coupé in Monaco Blau with all the optional trimmings
