Frustrating Outside Tap Connector
- Adam D
Brrrr cold outside, it’s a bit faded but you can see the part - should be available in b&q etc
- 2BA1B1E0-9E7F-4198-801C-2C9F97C48F21.jpeg (597.12 KiB) Viewed 1210 times
Silver Grey 2007 Z4MR which needs to be driven more
- TitanTim
Online
I always isolate the garden tap from in side and. then leave the tap open to drain. If/when it freezes, any ice will expand through the outlet of the tap
I'm amazed how many people I get called to where their o/s tap has frozen and split and they don't have an isolating tap inside
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- TitanTim
Thanks bobby, the plumber has fitted an inside isolator valve although I would have preferred a lever type now as it's a little fiddly under the kitchen sink as I tend to switch the supply off until I need to use the tap. Think I'm a little paranoid that someone could switch the tap on as a prank while I'm not home and being on a water meter not what I'd want. The cover I have is really just to keep the general weather off the tap and stop corrosion etc.firebobby wrote: ↑Sun Oct 29, 2017 1:08 pmI always isolate the garden tap from in side and. then leave the tap open to drain. If/when it freezes, any ice will expand through the outlet of the tap
Tim.
- Boris
Online
Hi Tim, that would be easy to fit a lever type valve there, I found some of those screw driver type isolator valves leak. Has he used PTFE tape on the olive joints ??
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- GBZ4
- TitanTim
I think so, there looks to be the white tape on the joints, is that good or bad?
Tim.
Online
It's not needed Tim, PTFE tape is for threaded joints. In a compression joint, the olive is the seal. I normally pull any of our contractors I see using it on compression fittings.
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- TitanTim
Hopefully it won't leak
Tim.
- TitanTim
- ronk
PTFE
Plumbers Tape Fixes Everything !
