Number plate change . . .
Marlon
Post by Marlon » Thu Sep 28, 2017 10:25 am
Was checking my car out on cazana and looking at the MOT history. It shows several number plate changes, which is fine. However it shows a change of plate when first registered in April 2008 that doesn't make sense to me?
How can the first plate be a private reg? Surely when registered it should have an '08' plate?
plate change.JPG (72.56 KiB) Viewed 1124 times
Gone: 3.0si 2008 E85
911 997 Carrera S
Ducklakeview
Post by Ducklakeview » Thu Sep 28, 2017 10:45 am
The dealer can assign a retained plate to a new car upon first registration with their AFRL (automated first registration & licensing) system, done it many times when I was at a main dealers.
Mike
Marlon
Post by Marlon » Thu Sep 28, 2017 10:46 am
Ah right - makes sense, cheers Mike
911 997 Carrera S
PerryGunn
Post by PerryGunn » Thu Sep 28, 2017 10:47 am
Nope, if you have a private plate on retention (or a transfer certificate) that can be assigned to a car at first registration - it's even easier with the new on-line system
We did this with our new X3 that we picked up at the end of December and transferred the private plate off our old X3 onto the new one when we went to the dealers to pick it up - took about 10-15 mins
If you later take the private plate off the car it's assigned a new age-appropriate registration by the DVLA
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
PerryGunn
Post by PerryGunn » Thu Sep 28, 2017 10:49 am
- too slow, I see Mike replied while I was typing that... :lol:
Marlon
Post by Marlon » Thu Sep 28, 2017 10:50 am
Still puzzled actually - why would you assign your private plate J44JHJ in April 2008 and then in the same month reassign to PK06ZGA?
911 997 Carrera S
Ducklakeview
Post by Ducklakeview » Thu Sep 28, 2017 11:28 am
Marlon wrote: Thu Sep 28, 2017 10:50 am Still puzzled actually - why would you assign your private plate J44JHJ in April 2008 and then in the same month reassign to PK06ZGA?
When it was rung??
:D
Mile
GBZ4
Post by GBZ4 » Thu Sep 28, 2017 12:24 pm
I just checked my Zed on Cazana. It was itnitally registered from a retention certificate, it says ‘It had been previously registered under EN**NYD’.
That’s not possible, the registration quoted was a previous BMW that had my private plate assigned to it.
Therefore, don’t believe everything you read as it does contain misleading information :o
2016 E89 18i Roadster - gone and forgotten
rally-chris
Post by rally-chris » Thu Sep 28, 2017 1:11 pm
That's probably the truth of it - the 06 reg was what went onto the car that the private plate cans off when the OP's car was first registered.
08 Z4 3.0si Sport Coupe in Montego Blue
rally-chris
Post by rally-chris » Thu Sep 28, 2017 1:14 pm
I think the cadenza site just links together bits of information from multiple sources, rather than being a credible, maintained database itself. It associates data relating to a car via the registration number with some sort of time window applied to try filter out the same registration being transacted on another vehicle.
Chris
Marlon
Post by Marlon » Thu Sep 28, 2017 1:25 pm
interesting - quickly losing faith in cazana :(
911 997 Carrera S
Dav the wheel nut
Post by Dav the wheel nut » Thu Sep 28, 2017 1:54 pm
Marlon wrote: Thu Sep 28, 2017 10:25 am Was checking my car out on cazana and looking at the MOT history.
Ever thought about getting a hobby :poke:
Marlon
Post by Marlon » Thu Sep 28, 2017 2:24 pm
Dav the wheel nut wrote: Thu Sep 28, 2017 1:54 pm
this is my hobby :P
911 997 Carrera S
IRD
Post by IRD » Sat Oct 07, 2017 8:09 pm
As above. Bought a new daily a couple of months ago and had wife’s plate assigned to it. Dealer dealt with it. I just provided retention certificate.
