Tyre Suggestions
Alloy wheels and tyre discussion
barnyg
Tyre Suggestions
Post by barnyg » Tue Jul 04, 2017 9:21 pm
Hi guys,
Have been really loving getting to know my new E86 but one thing that is needs imminently is a set of front tyres due to the tread being low. Its currently on Vredestein Ultrac Sessanta 225/40 ZR18 92Y with some other Vredesteins on the rears (but these were only recently changed and will be staying on the car). Was inclined to replace like for like but nowhere local seems to be able to get those tyres in. Have any of you guys got any suggestions what might be a good tyre to swap to. Ideally it would be something my local is likely to have in or can get in fairly easily.
Cheers,
Barny
[SOLD] 2006 Z4 3.0si Coupe: Montego Blue, Cirrus Dash, Cruise Control, Nav, 18" CSL Reps, Eibach lowered, MM Tips, ZHP Gearknob, Sport Button mod, GROM BT3
bmwaddict
Tyre Suggestions
Post by bmwaddict » Tue Jul 04, 2017 9:27 pm
My daily has Goodyear Eagle F1s, great all rounder, amazing in the wet, very confidence inspiring, but compromise all out dry speed because of the all weather ability. Not as expensive as Michelins and Conti's and last well. Good availability too, order from Camskill and get your local mobile tyre fitter to change for you - you'll save a packet.
Currently zedless :(
'07 Mugello Blue Audi B7 RS4 Saloon with added goodies
'94 Black/Silver/Green Honda CBR400RR
Previous:
'07 Ruby Black Z4MC
'07 Sapphire Black Z4C 3.0si Sport
Marlon
Tyre Suggestions
Post by Marlon » Tue Jul 04, 2017 9:44 pm
Whats wrong with replacing with the Vreds you are currently running - good tyre imo.
If you want a change then I agree with bmwaddict go for Goodyear Eagle F1s
Gone: 3.0si 2008 E85
911 997 Carrera S
barnyg
Tyre Suggestions
Post by barnyg » Tue Jul 04, 2017 9:46 pm
Meant to say the fronts are low on tread hence the needing to change but the rears are absolutely fine and will be staying! I'll change my original wording.
Status
Tyre Suggestions
Post by Status » Wed Jul 05, 2017 10:20 am
Just put two Goodyear F 1 s on the front of mine,done away with the dreadful runflats,went up to Snowdonia over the weekend and they performed very well,as usual it rained as expected in Wales ,car was transformed just by changing the fronts
barnyg
Tyre Suggestions
Post by barnyg » Wed Jul 05, 2017 1:17 pm
Thanks for your responses. I think I agree the Goodyear eagle f1s look good. Reasonable price and good ratings in terms of wet weather performance/fuel economy.
buzyg
Tyre Suggestions
Post by buzyg » Wed Jul 05, 2017 4:32 pm
You should be able to get Replacement VREDS on line and then pay a local tyre shop to fit & balance them. Bare in mind, You'll need another vehicle to move the tyres to the tyre shop. Or you can just take the wheels and leave the Zed on stands for an hour.
I moved over from VREDs to MPSS a few years back. Both good tyres on the E85. I can vouch that they work well with MPSS on the front and VREDS on the year, as I also swapped mine out tow by two. :)
ferry
Tyre Suggestions
Post by ferry » Fri Jul 07, 2017 5:34 pm
I order online and ship to my fitters. Much cheaper than going somewhere and buying off the shelf and gives a full choice of tyres available.
My shortlist looks like:
Continental Sport Contact 5
Goodyear Eagle F1 Ass. 3
Michelin Pilot Sport 4
Blackcircles.com and camskill are my first ports of call.
barnyg
Tyre Suggestions
Post by barnyg » Fri Jul 07, 2017 5:40 pm
Hi guys, thanks for the inputs. Got the tyres changed this morning and went for the Goodyear Eagle F1s. Already noticing the ride seems a bit smoother. Went for a full alignment to make sure i'm off to a good start too.
bz4kev
Tyre Suggestions
Post by bz4kev » Fri Jul 07, 2017 6:16 pm
barnyg wrote: Fri Jul 07, 2017 5:40 pm Hi guys, thanks for the inputs. Got the tyres changed this morning and went for the Goodyear Eagle F1s. Already noticing the ride seems a bit smoother. Went for a full alignment to make sure i'm off to a good start too.
how much was the alignment and who did you use :thumbsup:
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
csquire4
Tyre Suggestions
Post by csquire4 » Sun Jul 09, 2017 9:21 am
2004 3.0i, manual, toledo blue
barnyg
Tyre Suggestions
Post by barnyg » Sat Jul 15, 2017 3:37 pm
Bz4kev, alignment ended up being £60 with all 4 wheels needing adjustment, went with our local merityre for convenience
highway1
Tyre Suggestions
Post by highway1 » Sun Jul 30, 2017 7:05 pm
The latest tyre test ( Auto express) done on a VW Golf , and the winner was the Michelin pilot sport 4.
Surprisingly, the Goodyear F1 A3 didn't do that well.
I have Goodyear F1 A2 (non run flats) on my Coupe at the moment and they seem good but I cant compare as that's what they had when I bought the car!
I am changing to 18's soon ( if the drives not too compromised by the larger wheels) and will probably put some of those Michelin Pilot Sports on them although I suppose what works best on a Golf might be different on a rear wheels drive Coupe with staggered wheels!
Havard
Tyre Suggestions
Post by Havard » Sun Jul 30, 2017 11:44 pm
Always found that Vreds and Continentals keep me out of trouble.
H.
