Will these tyres be too wide?
Alloy wheels and tyre discussion
oalloyd1
Post by oalloyd1 » Sat Jun 03, 2017 11:21 am
Hi all,
I'm looking at running a 17" square set-up on my 2003 Z4 3.0 E85 and want to check if they'll be a risk of rubbing at the front - this is key as it's going to be a track car.
I'm going to use 8.5J and the usual tyre size for this would be 245
https://www.ebay.co.uk/itm/331508202103
My question is if I use the attached tyres will they rub if the car has been lowered 30mm or so? Or will they run anyway if I lower it or not?
Cheers all!
o :)
markplant
Post by markplant » Sat Jun 03, 2017 1:07 pm
Have you tried using will they fit.com
mr wilks
Post by mr wilks » Sat Jun 03, 2017 1:35 pm
You need the offset numbers to come up with a answer & whilst you mention 245 the link shows 255 40 tyres :? is that your plan for the fronts :cry:
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
