Metal dust cap stuck on tyre valve
- Diamond Gaz
So, have gone to check the tyre pressure, and one of the metal dust caps which were already on the car, is jammed stuck and will not budge. Have tried WD40, pliers, molegrips, all with no luck.
Can anyone give me any other ideas for shifting it, or know if tyre fitters will replace valves on run flat tyres please?
3.0si 06 Montego Blue Roadster
- Chris_D
oh dear, you silly sausage!
metal dustcaps are just a big fat NO-NO! *waves finger*
blowtorch... that one your missus keeps in the bottom cupboard in the kitchen for caramelising the top of a creme brulee will do
heat up for approx 30 seconds trying not to destroy the wheel laquer, then try pliers again.
this, i hasten to add should be your LAST resort. lash the WD on/in it and leave overnight to penetrate if you can. it's penetrating fluid.....so eventually it will penetrate and you should be able to gradually plier them off....
good luck
good luck
- Nictrix
Metal dustcaps are what should be used on all vehicles, as long as they are not the crap aluminium ones.Chris_D wrote:oh dear, you silly sausage!
It has been known for centre of the valves to be blown out and the plastic valve covers do not stop this from happening leading to an instantly flat tyre.
Metal dustcaps with the rubber seal can also stop air escaping from the valve, allegedly.
I'd take it to a garage and get them to remove the cap. If it damages the valve with the twisting force they can replace it there and then and you won't be stuck at home needing a new valve and flat tyre.
2005 Z4 3.0 Black, Zhp gear knob.
- Smartbear
I was always led to believe wd40 is a moisture dispersant & not a penetrating fluid, try plus gas instead as that is definitely penetrating fluidChris_D wrote:oh dear, you silly sausage!
good luck
e85 3.0si sold
- Chris_D
ii used to use metal caps as i thought they would give a bit more protection and they would become 4 less things to be concerned about. i also used to give the valve threads a smearing of copper grease so they wouldnt get stuck but i got caught out in poland one winter where it was -15 and i had to top up a tyre with a bit of air. ofc one was stuck and it took ages to get it off in the biting wind and snow. and for that reason alone i'll never use metal caps again!Nictrix wrote:Metal dustcaps are what should be used on all vehicles, as long as they are not the crap aluminium ones.Chris_D wrote:oh dear, you silly sausage!
- Nictrix
Fair enough, the plastic ones will never seize on and will save a massive amount of weight.Chris_D wrote:ii used to use metal caps as i thought they would give a bit more protection and they would become 4 less things to be concerned about. i also used to give the valve threads a smearing of copper grease so they wouldnt get stuck but i got caught out in poland one winter where it was -15 and i had to top up a tyre with a bit of air. ofc one was stuck and it took ages to get it off in the biting wind and snow. and for that reason alone i'll never use metal caps again!Nictrix wrote:Metal dustcaps are what should be used on all vehicles, as long as they are not the crap aluminium ones.Chris_D wrote:oh dear, you silly sausage!
If you check your pressures regularly the caps should never get to the point where they seize on.
- Chris_D
yeah def. check every week / 2 weeks usually but this was when i was setting off back to holland from Warsaw and doing all the usual pre-flight checks etc. fekin freezin in poland sometimes! a van driver at the petro lstation had one of those wind-proof lighters and lent me it to heat up the cap and bob's yer uncle - it freed up!Nictrix wrote:Fair enough, the plastic ones will never seize on and will save a massive amount of weight.Chris_D wrote:ii used to use metal caps as i thought they would give a bit more protection and they would become 4 less things to be concerned about. i also used to give the valve threads a smearing of copper grease so they wouldnt get stuck but i got caught out in poland one winter where it was -15 and i had to top up a tyre with a bit of air. ofc one was stuck and it took ages to get it off in the biting wind and snow. and for that reason alone i'll never use metal caps again!Nictrix wrote: Metal dustcaps are what should be used on all vehicles, as long as they are not the crap aluminium ones.
- kis
Happened to me on the bike. Had nice fancy swish looking aluminium ones
Had fused itself on! Couldn't get the bugger off, in the end I got a pair of pliers to help twist and it ended up ripping a hole in the stem! So if you're lucky you'll be able to coax it off. If not your might need a new valve? Or you could hack off the top with a dremmel or something to pump in enough air to see you to the local tyre place? If in doubt remove the wheel and take in another car? By far the safest thing!!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
I've had this on a car I bought, I used mole grips to hold the stems and a small spanner to undo. Plastic ones were fitted.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Diamond Gaz
Tried that and it hasn't worked My main concern was whether you could replace a tyre valve on a run flat tyre, (never had them before), Decent local tyre fitters that I use reckon its no problem, and will only cost around £10 to replace with a new valve, so going to take the wheel off the car and take it down to them to replace the valve and then I'll replace the dust cap with a plastic one. Thanks for all the ideas though.firebobby wrote:I've had this on a car I bought, I used mole grips to hold the stems and a small spanner to undo. Plastic ones were fitted.
- Mr Tidy
Looks like you have found a solution OP.
Fortunately the TPWS on E85/86s doesn't use a sensor in the valve!
Learnt my lesson with alloy caps on my 123d - won't be using them again!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Stuartt
As you have now found out your local tyre shop will sort you out no problem with a very small fee
I have metal valve caps and have no problem as applied a small amount of copper grease to the thread before fitting to stop the corrosion.
Stuart
Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
I put some branded, aftermarket (cheap) metal caps I bought off ebay on my Audi A5 a few years ago. Within 2 months the chinese rubbish caps had corroded and seized on.
Eventually got them off with a cooks blow torch, mole grips and pliers.
They were similar to these, best avoided.
http://www.ebay.co.uk/itm/AUDI-Chrome-W ... SwgQ9VjUGM
2004 3.0i, manual, toledo blue
- ric19
Happened to me the other week,ended up using a Dremmel to cut through it, so Ive been an oiled all mine up now
