Much covered - Wheel size/fitment
Alloy wheels and tyre discussion
Wilky
Post by Wilky » Wed Jan 04, 2017 11:34 pm
Hi, appreciate it's a much covered subject however I'm thinking of purchasing a set of alloys, this is the size fitment blurb:
Width: 8.5J
Diametre: 18"
PCD; 5/120
Offset: Et35
CB: 72.6
Finish: Hyper Black
However my concern is putting 8.5J on the front as well as the rear. Also is the offset suitable for use with out spacers etc.
All discussion/advice greatly appreciated. :thumbsup:
bmwaddict
Post by bmwaddict » Thu Jan 05, 2017 12:01 am
Should be ok, many are running 8.5 fronts here.
This may help: http://www.willtheyfit.com
Currently zedless :(
'07 Mugello Blue Audi B7 RS4 Saloon with added goodies
'94 Black/Silver/Green Honda CBR400RR
Previous:
'07 Ruby Black Z4MC
'07 Sapphire Black Z4C 3.0si Sport
Wilky
Post by Wilky » Wed May 03, 2017 9:10 am
Much covered but suffering from information overload :headbang: regards alloys and offset are these possible or are they too borderline for the inner lip of the wing?
specs =
front = 18" x 8.0" et34 with 225/40r18
rear = 18" x 8.5" et37 with 225/40rr18
Will be fitted to a 2006 2.5 roadster, I've a sneaky feeling it's unwise but have the chance of next to new 7 month old 18 CSL replicas with brand new tyres virtually for £400 . They were on an E46 2003
Any advice, response, dissuasion, or suitable words of wisdom greatly appreciated.
Thanks Simon :thumbsup:
vester86
Post by vester86 » Wed May 03, 2017 11:35 am
Wilky wrote: Wed May 03, 2017 9:10 am Much covered but suffering from information overload :headbang: regards alloys and offset are these possible or are they too borderline for the inner lip of the wing?
specs =
front = okay, but close to the limit with this tyre/wheel combo
rear = good
both are 13mm further out then standard OEM sets (108 or MV2)
Wilky
Post by Wilky » Wed May 03, 2017 12:27 pm
Thanks Vester, OEM...?
When you say the fronts are close is that to close..? Have you tried/experienced them previously . Will it adversely affect the handling or tyre wear.
Once again thank you for taking the time to reply it's greatly appreciated. They're a cracking set at a great price I just don't want a set that is going to catch or foul on anything.!
Cheers Simon
Buckz
Post by Buckz » Wed May 03, 2017 12:36 pm
Wilky wrote: Wed May 03, 2017 12:27 pm Thanks Vester, OEM...?
Cheers Simon
I wouldn't worry about it tbf!
on my z4 coupe I ran CSL reps with -;
19x8.5 et38 front with 235/35/19 tyre
19x9.5 et40 rear with 255/30/19 tyre
and had 0 issues/rubbing.
you will be fine with a 8" rim with 34offset and stock tyre size - aka 225/40/18
StigJ
Post by StigJ » Wed May 03, 2017 12:56 pm
I have 8,5" ET34 in the front with 225/35-19. Works like a charm. 235/35 did not work...
Hellrot '06 BMW Z4 Coupe 3.0si
Instagram: @StigJ77 & @bmwe86driver
vester86
Post by vester86 » Wed May 03, 2017 2:33 pm
Cheers Simon
OEM = original Equipment Manufacturer.
don't worry, you will be fine.
front are close but not TOO close. as StigJ mentioned, don't try a 235 tyre as that will rub with these wheels.
i've experienced 8J 235/40//18 with an et35 and that rubbed slighly under hard cornering. 225/40/18 will be perfect
stance will be beautiful
Neilc
Post by Neilc » Wed May 03, 2017 3:24 pm
With standard suspension you will be fine, I've got 19 x 8.5, 235 35 at the front with a 30mm drop so with 18's it should be fine.
2.5Si Stirling grey Z4, green cotton induction kit, front & rear strut brace, clear third brake light, 19" deep dish alloys, Eibach Pro springs and colour coded duck tail spoiler.
patriot66
Post by patriot66 » Wed May 03, 2017 6:32 pm
specs =
They will be fine. I have 18" MV3s in those widths and offsets on my '03 2.5i, although my rear tyres are 255/35 R18. I don't get any rubbing front or rear at all. :thumbsup:
mjennings23
Post by mjennings23 » Sat May 06, 2017 8:36 pm
Have a friend who might be selling his gunmetal refurbed MV3s so this is good to know, should work against the black of the car too
patriot66
Post by patriot66 » Sat May 06, 2017 9:06 pm
mjennings23 wrote: Sat May 06, 2017 8:36 pm Have a friend who might be selling his gunmetal refurbed MV3s so this is good to know, should work against the black of the car too
I agree. Gunmetal against black will look great. Also, as the offsets are et34 front and et37 rear they fill out the arches better and greatly improve the cars look and stance. No spacers needed ! :thumbsup:
samj89
Post by samj89 » Wed May 10, 2017 12:20 pm
I'm on 9j front with eibach no problems a
Slight rub going down hill backwards on full lock
Carbon black Z4MC with Champagne extended leather, carbon dash. Eibach
front H&R rear, 1m /m3 GTS wheels
mjennings23
Post by mjennings23 » Thu May 11, 2017 8:57 pm
Well MV3s in silver are incoming, with a relatively new set of Pirelli tyres on too so not bad at all!
