19" tyre sizes for CSL reps
Alloy wheels and tyre discussion
TomK
Post by TomK » Tue Apr 25, 2017 3:55 pm
Argenta wrote: Tue Apr 25, 2017 3:43 pm This is a Z4 forum - not a M3 forum. ;)
Well yes, but given that a z4m nicks pretty much all it's running gear from an m3 I'd go along with what BMW did rather than a load of internet opinions about what might be the best tyre size :P
That said I run different 18" tyre sizes to oem, so I'll get back in my box :D
Argenta
Post by Argenta » Tue Apr 25, 2017 6:22 pm
Exactly, "pretty much"... The transmission and final gear is different, not even the S54 is identical to the M3.
I don't know why anybody would go against BMW original dimensions. :)
With smaller-than-std rear wheels the ride suffers, speedo/odometer misreads and looks suffer (matter of taste obviously but certainly to me). Also it doesn't help with the Z4M's notoriously low gearing which does make it a bit revvy on the highway.
TomK
Post by TomK » Tue Apr 25, 2017 6:46 pm
Argenta wrote: Tue Apr 25, 2017 6:22 pm Exactly, "pretty much"... The transmission and final gear is different, not even the S54 is identical to the M3.
Well I've never heard of the Z4M being referred to as low geared, it is geared in 6th for speeds that it is unable to pull. Off topic but I am very keen to shorten my final drive ratio, I have no need of gearing to 185mph or whatever it is.
If you're referring to me when saying can't understand why anyone would go against bmw's recommendations then I'd answer that I wanted to increase the width of the tyre slightly ala csl (I have the same power as one) and correspondingly bought wider rims to suit. One of the reasons I wanted to keep 18" as I agree a 265/30 19 is going to be a hard ride.
Thing is there is no bmw recommendation for our cars on 19" so regardless of whether the transmission or final drive are different I would be more concerned with suspension kinematics, and considering a csl is really not far from our cars in terms of weight that would be the direction I would choose when running a 19" on a csl wheel.
Also a 265/35 19 is a bit of a balloon no, and must weigh a fair bit more?
I guess there's no real correct answer here though
:D
Philly_Sweden
Post by Philly_Sweden » Tue Apr 25, 2017 7:44 pm
I've never heard anyone running 265/35 before but it might work just fine. I still prefer running on OEM CSL tire spec and have always done before on 2 M3's and on my previous Z4M as well.
TomK
Post by TomK » Tue Apr 25, 2017 8:11 pm
ignore.. brainfade edit post
Argenta
Post by Argenta » Tue Apr 25, 2017 8:58 pm
I never wrote Bmw has any "recommendations" regarding wheels?
I wrote "against Bmw original dimensions" - meaning OEM Bmw Z4M wheel size. :)
TomK
Post by TomK » Thu Apr 27, 2017 5:44 am
Argenta wrote: Tue Apr 25, 2017 8:58 pm I never wrote Bmw has any "recommendations" regarding wheels?
What I can't understand is, if you are so keen to keep oem bmw Z4M wheel size why you didn't go with 225/40 and 255/35 on your 19s which are the exact same diameter and width to oem 18s 225/45 & 255/40?
Argenta
Post by Argenta » Fri Apr 28, 2017 9:43 am
Well, my mistake! :)
But I was looking for 235/265 tires I think because they match the wider rims best in width. Also, as above, the higher gearing and better comfort was further reasons.. Maybe next time!
I usually try to stay at least within 1% of original diameter (so 3% would be right out).
TomK
Post by TomK » Fri Apr 28, 2017 6:42 pm
If I was running a fairly standard car on 19s that would be my choice personally...
Many M3 CS's came from the factory with the wider CSL 8.5" front (instead of the CS 8j front) and obviously the same 9.5j rears. These were delivered by BMW with 225/40 and 255/35 so you shouldn't have any worry there. (in terms of wheel width/vs tyre width) :)
AlfaScozzesi
Post by AlfaScozzesi » Fri Apr 28, 2017 7:13 pm
TomK wrote: Fri Apr 28, 2017 6:42 pm If I was running a fairly standard car on 19s that would be my choice personally...
Think the CS wheels are only different on the fronts as you said 8J and 8.5J. The backs were 9.5J on both CS and CSL. Same part number as well.
