Tyre sizes for BBS 108s
Alloy wheels and tyre discussion
Phil Coleman
Post by Phil Coleman » Mon Nov 27, 2017 2:00 pm
Just got some used 108s for the Z, they need a refurb but they'll be OK for now until winter has passed. The wheels came with tyres on the front (Falkens) 225/40/18 but the rears didn't so I bought some part worn 255/35/18's.
Was wondering if I can put either 255/40/18 or 255/45/18 on the back as the 255/35/18 look rather skinny compared to the front.
Phil
Screen Shot 2017-11-27 at 12.45.12.png (1.99 MiB) Viewed 834 times
Steve84N
Post by Steve84N » Tue Nov 28, 2017 1:33 pm
I use 245/40/18 which is a slight increase in sidewall.
You don't need more than 245 with this much power/torque, the speedo is then much more accurate with this size and it reduces understeer as you have less F/R stagger.
C63 AMG Estate 6208cc
Z4 Gaz
Post by Z4 Gaz » Tue Nov 28, 2017 2:14 pm
255 35 is the correct size and only 0.07cm smaller than the 225 40 sidewall.
Have a look here to see the differences aspect ratio changes make.
http://www.kouki.co.uk/utilities/visual ... calculator
E85 3.0i
Steve84N
Post by Steve84N » Tue Nov 28, 2017 2:18 pm
True but if you want something else the 245/40 has a lot going for it. :thumbsup:
philbo909
Post by philbo909 » Tue Nov 28, 2017 2:31 pm
Steve84N wrote: Tue Nov 28, 2017 2:18 pm True but if you want something else the 245/40 has a lot going for it. :thumbsup:
255 on 8.5j looks a bit over-rubbered too, 245 could be a better shout
Sapphire black z4 coupe 135,000miles young
Steve84N
Post by Steve84N » Tue Nov 28, 2017 2:35 pm
Yep, 255 is the limit of what's recommended for 8.5J and most manufacturers run at least a 9J if they spec 255. A 245 still overhangs slightly so you get rim protection.
