Hi,
Please could you give me some advice on what sensible tyre size to run on a square set 8.5 x 18 ET35 rims on an 08 E86 Coupe (std Sport suspension)? I'm looking at getting a used set of Team Dynamics Le Mans rims for daily use, whilst I get my 108s refurbished and kept for summer/show use.
The new wheels are the same width as standard rears, albeit set 15mm further out (ET35 vs ET50), so will I be OK with standard tyre size, i.e. 255/35 18?
The fronts will be wider than standard (8") and by my calcs the outside of the rim will be nearly 25mm further out (ET35 vs ET47 + extra 12.7mm width), so will I need to be careful about tyre size? Will I get away with the standard size of 225/40 18 or will this look stupid on the wider rim anyway? I'm not a fan of the stretched look and I would prefer some tyre to protect the rim, so what else would fit?
Many Thanks!
Chris
Tyre Size Recommendation for 8.5 x 18 Rims - E86 Coupe
08 Z4 3.0si Sport Coupe in Montego Blue
hi Chris, a 225 isnt daft at all, ive run 225 40 on an 8.5 and its barely any stretch if anything, i think a 255 35 is 'over tyred' for a 8.5j rim, for example, the m135i (with all that power) runs a 245/35 on a 8.5j rear wheel out of the box, so with a 225/40 front and 255/35/18 you'll be fine and not encounter any rubbing , presuming your at std height?rally-chris wrote: ↑Wed Sep 13, 2017 10:53 am Hi,
Many Thanks!
Chris
18 Z4s owned to date.
Current: 2.5i Titan silver
Thanks Jamie - yes, I'm on standard (Sport) ride height and no plans to lower it (or else I might not get out of my driveway!).jamie_z4 wrote: ↑Wed Sep 13, 2017 10:58 amhi Chris, a 225 isnt daft at all, ive run 225 40 on an 8.5 and its barely any stretch if anything, i think a 255 35 is 'over tyred' for a 8.5j rim, for example, the m135i (with all that power) runs a 245/35 on a 8.5j rear wheel out of the box, so with a 225/40 front and 255/35/18 you'll be fine and not encounter any rubbing , presuming your at std height?rally-chris wrote: ↑Wed Sep 13, 2017 10:53 am Hi,
Many Thanks!
Chris
- patriot66
My Zed's a roadster with Sport springs fitted and I'm running 255/35 18 rear and 225/40 18 front mounted on MV3s, rear ET37 and front ET34. The rears are absolutely fine and never catch or rub. The fronts catch slightly on the top leading outer edge of wheel arch liner but ONLY when the car goes into some high speed compression bumps, no other time.
- 1doohan
Running 255/40 18 on rear
- Z4 COUPE (2).JPG (209.96 KiB) Viewed 979 times
Z4C Sapphire Black 398s Whippy
M4 Competition
M4 Competition
- Buckz
I'm running et30 8.5 with 225 on front on my other set and the exact same thing, catches a tiny bit on high speed bumps but 99% of driving it doesn't rub at all.patriot66 wrote: ↑Wed Sep 13, 2017 6:26 pm My Zed's a roadster with Sport springs fitted and I'm running 255/35 18 rear and 225/40 18 front mounted on MV3s, rear ET37 and front ET34. The rears are absolutely fine and never catch or rub. The fronts catch slightly on the top leading outer edge of wheel arch liner but ONLY when the car goes into some high speed compression bumps, no other time.
Follow up to the OP - I went with standard Z sizes on the 8.5” ET35 Le Mans rims and all seems well so far.
Chris
Chris
