Replacement wheel centres
Hi
I need to get some new wheel centres for my 108s. The existing ones have got peeling centres but the plastic outer lip is fine.
Has anyone tried these http://www.ebay.co.uk/itm/4-x-BMW-68mm- ... 8579&rt=nc
As a cheaper alternative?
2003 Z4 3.0 SE Roadster. Manual, silver with New England red extended leather. Pro nav, xenons, carver hifi, elec fold mirrors, 6CD, dension gateway 100 iPod adaptor, tv, 108s, wind deflector. Fitted: Stubby, cruise control, ZHP, cup holders.
- GP06Roadster
Re: Replacement wheel centres
I have always bought OEM. They are expensive at about £36 IIRC for a set of four but they are quality and snap in tightly. I've read done of the aftermarket fleabay ones can be a little loose fitting.
E86 3.0si Manual
- sk93
yep.
if the ones you get are a bit loose, just put a layer of electricians tape around the inside lip of the wheel, then push the cap in.
Holds them perfectly in place!
- Sae
That's a top tip, I was going to use a tiny drop of silicon sealant for extra snugnesssk93 wrote:yep.
Z4MCoupe Sapphire Black
- sk93
silicon works well, until it dries and gets sticky and you go get your wheels balanced.... new cap requiredSae wrote:That's a top tip, I was going to use a tiny drop of silicon sealant for extra snugnesssk93 wrote:yep.
Send an email to Ian Clifton at [email protected] and tell him what you are after and ask him to send you a PDF brochure.
- sk93
really don't bother.Dav the wheel nut wrote:Send an email to Ian Clifton at [email protected] and tell him what you are after and ask him to send you a PDF brochure.
I got this advice, and just found he was WAY more expensive the eBay
(like, a front bonnet badge in carbon fiber - he wanted about £70.)
- andysat
sk93 wrote:really don't bother.Dav the wheel nut wrote:Send an email to Ian Clifton at [email protected] and tell him what you are after and ask him to send you a PDF brochure.
Gone but not forgotten.
New ride silver e93.
I've just checked his brochure and it is £13 for a genuine carbon fibre bonnet badgesk93 wrote:really don't bother.Dav the wheel nut wrote:Send an email to Ian Clifton at [email protected] and tell him what you are after and ask him to send you a PDF brochure.
Genuine ones for £36/set? Where?!
- sk93
PLUS the price of a new badge from BMWDav the wheel nut wrote:I've just checked his brochure and it is £13 for a genuine carbon fibre bonnet badgesk93 wrote:really don't bother.Dav the wheel nut wrote:Send an email to Ian Clifton at [email protected] and tell him what you are after and ask him to send you a PDF brochure.
- sk93
here's a reply from my email chain with him, he's replying to my comment of "How much?!"
£38 + vat = £45.60 for new badge
£45.60 + £13 = £58.60 for new badge recovered in carbon
£58.60 + £5 = £63.60 for new badge, plus top, with an estimate of a fiver for shipping.
my call of £70 may have been an overestimate, but it was from memory from nearly a year ago... and not too far off the actual cost
The reason the front badge is so expensive is the base is OEM from BMW at approx £38 plus VAT + Gen Carbon top at £13 + delivery etc.
- GP06Roadster
itguy wrote:Genuine ones for £36/set? Where?!
Genuine BMW Alloy Wheel Centre Caps x4
http://bit.ly/1mj22Ws #ebayipad
£29.99/set even less than I paid
E86 3.0si Manual
Sorted! Thanks for the link
