E89 Smarttop Installation
- A1GSS
Well, just done this but it was a bit painful in places so I thought I'd share my findings
Windows.
1. The firmware is NOT in Windows update, so the instructions are wrong
2. The zip file of manually installable drivers provided by Mods4Cars has no installation script or wrapper
3. The manual instructions for how to install the drivers do not work on Windows 7 64 bit
4. Module not found without the drivers so thart's a show stopper
5. I gave up with Windows
Mac.
1. Mavericks and Yosemite need a terminal workaround which is provided, I have Yosemite
2. Plugged module into Mac and ran the provided terminal command to execute the workaround
3. Grabbed the M4C app from App store and ran it, hooray, works fine
4. Programmed the setup to match what I wanted and wrote back to module, all good
5. Made a note of my settings!
So, Mac install worked fine
Installing the module in the car
1. Instructions are accurate but the photo showing which box is the Conv roof control module is a bit different to what I found in my car
2. Best clue was the suggestion to look for the 'Long black plug and bright green plug'
3. It's much easier to get the plug off and refit the Smarttop harness plug if you also remove the other two rearward connectors from the control module first, then refit them when you're done
4. There is very little space to squeeze the harness in but it is possible
5. Good idea to leave the USB cable connected to the module and tuck it out of the way
6. Test before refitting the trim! Not after
7. Refitting trim is the reverse. went OK but very easy to drop the trim fixing clips down inside the inaccessible spaces... (only one lost)
Overall this took an hour including a cup of tea and the buggering about with Windows drivers.
Windows.
Mac.
Graham.
2011 Z4 23i sDrive Space Grey / Coral Red
- A1GSS
Re: E89 Smarttop Installation
Update on this - Windows drivers installation - download from Mods4cars site, extract to a folder then use device manager to browse to that folder and install the drivers.
Graham.
- jamesbond
Hello .. well done
I can appreciate how long it takes to post these " how - to articles " and make them accurate
many thanks for taking the time to post your article ... I for one found this most helpful and a interesting read
Born in Yorkshire ended up in Essex .. 35is Mel red now sold
Own 2 big cats (F type & XE S supercharged) looking for a z4 Hobby Car
z4 3.0i 03 - Z4 3.0i 04 - Z4 3.0i 05 - Z4 3.0i 03 - Z3M (s54) 03 Man - Z4M 06 - Z4M 06 - Z4M 07 -
Z4 35is 2014
Z4 35is 2014
- Stuartt
Hi going to fit mine tomorrow,A1GSS wrote: βThu Apr 09, 2015 12:46 pm Well, just done this but it was a bit painful in places so I thought I'd share my findings
Windows.
Mac.
Is it necessary to lift the roof halfway as per instructions or can you fit it by just opening the boot and accessing it all from there ?
The instructions donβt really say what to do once fitted, just says refit trim panels ............ nothing about closing the roof back down.
Thanks Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
- jabber
When I did mine I think doing it with the roof half open makes access easier especially if the z4 is fully speced and the compartment is full of kit. To close I just used the key fob. Also worth noting dont keep the key fob in your pocket during installas if you accidentally press the buttons the roof will move, not a good idea when working near the roof mechanismStuartt wrote: βWed Apr 04, 2018 1:11 pmHi going to fit mine tomorrow,A1GSS wrote: βThu Apr 09, 2015 12:46 pm Well, just done this but it was a bit painful in places so I thought I'd share my findings
Windows.
Mac.
Thanks Stuart
Z less again
- Stuartt
Thanks,jabber wrote: βWed Apr 04, 2018 1:22 pmWhen I did mine I think doing it with the roof half open makes access easier especially if the z4 is fully speced and the compartment is full of kit. To close I just used the key fob. Also worth noting dont keep the key fob in your pocket during installas if you accidentally press the buttons the roof will move, not a good idea when working near the roof mechanismStuartt wrote: βWed Apr 04, 2018 1:11 pmHi going to fit mine tomorrow,A1GSS wrote: βThu Apr 09, 2015 12:46 pm Well, just done this but it was a bit painful in places so I thought I'd share my findings
Windows.
Mac.
Thanks Stuart
Stuart
- A1GSS
Yes, having the roof half open made access to the bits of boot trim etc, easier.
Graham.
- Stuartt
Thanks Graham, done it yesterday took about 15 minuets, no issues having the roof half open and very easy to access like that.
Expensive bit of kit but worth every penny
Stuart
- A1GSS
- ronk
Itβs how the car should have come from the factory!
Hi - how do you get the roof to stop half way open? Possible silly question - just take your finger off the button?
Z4 β13 20i Mineral Grey
Z4 '07 2.5Si Montego Blue
- Smartbear
Unless youβve already got a smarttop module installed, then yesjamesgarbett wrote: βThu Feb 11, 2021 3:03 pm Hi - how do you get the roof to stop half way open? Possible silly question - just take your finger off the button?
e85 3.0si sold
- Papa_Zee
Yep, thats how mine works, when i want to clean in there. It stops and continues when you press again - My key ony opens as not progreammed and I'm thinking smarttop if I think I need it.jamesgarbett wrote: βThu Feb 11, 2021 3:03 pm Hi - how do you get the roof to stop half way open? Possible silly question - just take your finger off the button?
Cant the smarttop functione just be programmed in anyway - Anyone?
E89 35is
