Poorly 35i (Now Fixed)(sort of)
R.E92
Poorly 35i
Post by R.E92 » Tue Aug 22, 2017 5:11 pm
Mine went at 40k. If you've got a warranty then just sit tight until a misfire pops up then roll it in to the dealer for some new injectors.
Timdon
Poorly 35i
Post by Timdon » Wed Aug 23, 2017 1:47 pm
The injectors went on mine at 20,000 miles and replaced Under the extended warranty
ph001
Poorly 35i
Post by ph001 » Wed Aug 23, 2017 2:35 pm
It will be injectors so if you are still in warranty I'd get video evidence as per the above and try to persuade BMW to do the necessary. Out of warranty they are expensive to replace @ circa £1,200 for 6 + fitting. Incidentally the design changed at least twice over the lifetime of the E89 so any new ones fitted now are likely to be trouble free.
Dario - nice to see you are still hanging around the forums old friend. I remember you from a road trip to the Isle of Man many moons ago. I think I was known as SpunkyM back then ;-) I had the black S54 Z3M. I remember you had a Z4 with a mental exhaust and induction system :evil: . What a trip that was!
Maniac
Poorly 35i
Post by Maniac » Wed Aug 23, 2017 5:33 pm
I'll have to wait for it to be more 'faulty' as there are no error codes and the misfire/idle issue is fairly intermittent/inconsistent at the moment.
I Appreciate the feedback.
dario
Poorly 35i
Post by dario » Wed Aug 23, 2017 6:23 pm
Maniac wrote: Wed Aug 23, 2017 5:33 pm I'll have to wait for it to be more 'faulty' as there are no error codes and the misfire/idle issue is fairly intermittent/inconsistent at the moment.
Well you got the answers you were looking for.
dario
Poorly 35i
Post by dario » Wed Aug 23, 2017 6:25 pm
ph001 wrote: Wed Aug 23, 2017 2:35 pm It will be injectors so if you are still in warranty I'd get video evidence as per the above and try to persuade BMW to do the necessary. Out of warranty they are expensive to replace @ circa £1,200 for 6 + fitting. Incidentally the design changed at least twice over the lifetime of the E89 so any new ones fitted now are likely to be trouble free.
You got the car and Miltek exhaust right lol. IMMSMC this was a Spokey Wheeler organised run. But without a photo of you I stuck lol
mcbutler
Poorly 35i
Post by mcbutler » Wed Aug 30, 2017 5:08 pm
I have a 2009 23i with 77k on the clock. At 75k miles I had it terracleaned, amazing difference, smoother, quieter, and more mpg (bonus). Well worth a try on any vehicle over 25k, especially if your using supermarket fuel.....
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Smartbear
Poorly 35i
Post by Smartbear » Wed Aug 30, 2017 5:11 pm
mcbutler wrote: Wed Aug 30, 2017 5:08 pm I have a 2009 23i with 77k on the clock. At 75k miles I had it terracleaned, amazing difference, smoother, quieter, and more mpg (bonus). Well worth a try on any vehicle over 25k, especially if your using supermarket fuel.....
Unfortunately that won't clean the inlet valves on a direct injection engine :o
How much did this cost you?
e85 3.0si sold
mcbutler
Poorly 35i
Post by mcbutler » Wed Aug 30, 2017 5:19 pm
Smartbear wrote: Wed Aug 30, 2017 5:11 pm
£50, direct injection engines often inject straight onto the back of the inlet valve, one of the reasons for deposit build up in the area. I am not sure of the exact direction of the injected fuel but will check out your info, many thanks. Regardless its worth a go.....
Mark
Plymouth
E89
35i
Carmine Red
Black leather
mcbutler
Poorly 35i
Post by mcbutler » Wed Aug 30, 2017 5:25 pm
mcbutler wrote: Wed Aug 30, 2017 5:19 pm
Just called the guy who did it for me, Terraclean use an adapter for DI engines that allows the inlet valve to be cleaned.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Z4M-2006
Poorly 35i
Post by Z4M-2006 » Wed Aug 30, 2017 5:33 pm
Direct engines inject straight into the combustion chamber,valve coke build up just above the stellite face on the valve is caused because air/fuel mixture not passing over it.
Z4M-2006
Poorly 35i
Post by Z4M-2006 » Wed Aug 30, 2017 5:43 pm
I thought terraclean worked my pumping a concentrated fuel cleaner through you fuel system and injectors ?
Maniac
Poorly 35i
Post by Maniac » Mon Sep 04, 2017 11:07 am
So the car is booked in for next week but in the meantime I've put in some RedEx for the last tank full and it's improved... think I may cancel the appt and just see if it continues to improve as there's no missing now just a slightly lumpy idle when cold and I've still half the redex to go....
dario
Poorly 35i
Post by dario » Mon Sep 04, 2017 12:25 pm
Maniac wrote: Mon Sep 04, 2017 11:07 am So the car is booked in for next week but in the meantime I've put in some RedEx for the last tank full and it's improved... think I may cancel the appt and just see if it continues to improve as there's no missing now just a slightly lumpy idle when cold and I've still half the redex to go....
Sounds like a plan
Maniac
Poorly 35i
Post by Maniac » Fri Sep 15, 2017 6:56 pm
Sigh, the rough when cold running has returned. The longer the car stands the rougher it's next start. Still no codes though, don't want to risk diagnostic fees until it's showing codes.
It's not a regular misfire, it's spotty. It's also bouncing revs when I try and hold them other than at idle.
