28i - Possible Boost Issue?
SteveSmith
Post by SteveSmith » Fri Jun 30, 2017 6:08 pm
Hi guys,
Driving home tonight with the roof down in sports mode and manual mode and whilst off the throttle I thought I heard a bit of a "dump valve" noise.
When I pressed on it didn't sound the same, you normally hear a bit of spooling etc plus it didn't feel as fast.
I've tried to look for any lose hoses etc but can't see anything.
Then I booted it again and it felt ok, then the next time it felt flat again.
Is there any common faults like this? Could the "dump valve" be sticking?
28i M Sport - Alpine White / Canberra Beige, 19" M359’s, H&R’s / Eibachs, BMS Stage 1 - 271bhp, Front Splitter, CF Rear Lip, Alcantara Steering Wheel and Brembo 4 pots
SteveSmith
Post by SteveSmith » Fri Jun 30, 2017 8:32 pm
Could it be the exhaust valve jammed closed? Or not opening on occasion? It seems fine one minute then it's very muted on downshifts another.
john-e89
Post by john-e89 » Fri Jun 30, 2017 8:41 pm
My thought went to an intermittent sticking wastgate Steve, if you can get to it spray some releasing fluid on it, it won't hurt, might smell a bit is all. Worth a try before you open your purse.. :)
MR2 MK 2
E89 35is
G29
SteveSmith
Post by SteveSmith » Fri Jun 30, 2017 8:47 pm
john-e89 wrote: Fri Jun 30, 2017 8:41 pm My thought went to an intermittent sticking wastgate Steve, if you can get to it spray some releasing fluid on it, it won't hurt, might smell a bit is all. Worth a try before you open your purse.. :)
That would definitely make sense! Thank you!
Any ideas where the waste gate is!?
Smartbear
Post by Smartbear » Fri Jun 30, 2017 9:11 pm
SteveSmith wrote: Fri Jun 30, 2017 8:47 pm
Hi Steve, your car either has a pneumatic wastegate actuator or a solonoid controlled one depending on date of manufacture-either can go wrong.
They are located on the l/h side of the engine as the turbo is part of the exhaust manifold
e85 3.0si sold
SteveSmith
Post by SteveSmith » Fri Jun 30, 2017 9:26 pm
Nice one! I'll have a look in the morning when it's cold!
john-e89
Post by john-e89 » Fri Jun 30, 2017 9:28 pm
I'm thinking actuator rod linkage as well. look on google where the turbo is and spray fluid in that area, I doubt you'll be able to get your head in there, or use a mirror,. The manifold will smoke afterwards but it'll soon dry off. That's not a long term solution but if it frees up for a day or two you'll know it's that.
MR2 MK 2
E89 35is
G29
Twin Turbo
Post by Twin Turbo » Fri Jun 30, 2017 9:34 pm
I would use and OBC reader - is there an owner near you with a carly?
viewtopic.php?f=2&t=97818&p=1438351&hil ... y#p1438351
Quick 10 minutes - will help to find out what the issue is.
SteveSmith
Post by SteveSmith » Fri Jun 30, 2017 11:49 pm
I have no engine management light.
Smartbear
Post by Smartbear » Sat Jul 01, 2017 7:28 am
SteveSmith wrote: Fri Jun 30, 2017 11:49 pm I have no engine management light.
Sometimes there can be a stored code despite there being no engine light on the dash :thumbsup:
e85 3.0si sold
SteveSmith
Post by SteveSmith » Sat Jul 01, 2017 11:34 am
Right, definitely the waste gate arm so thank you for that suggestion!
It was "out" when I first went to the car this morning, after about 30 seconds of driving it went back to normal, it's now returning and feels fine.
I'll keep my eye on it!
