Z4 35IS Sagging Height
- sunnydays
Hi guys,
The driver side rear of the car is sitting 2cm lower than the non driver side. Measured from the rear skirt down,
I thought this was a spring, so had my mechanic take a look but no broken spring was found, he said it may have been weakened which could cause the sag.
What else could cause a 2cm drop? Either way all 4 springs have been replaced just dont want the issue to still be their when i get the car back
So you've had the car to a mechanic who has experience and a view of the car that we don't have and he couldn't diagnose the fault?
Not much hope for us then. Would be total guesswork. If always measured on even ground then spring would be first guess. After that, name your suspension component as anything could contribute to it.
My suggestion, have another mechanic look over it.
- Smartbear
You have a flat tyre?
e85 3.0si sold
- Nictrix
Has the car been driven since it has been jacked off the ground?
if it hasn't, maybe the suspension just needs to settle.
After a car has been jacked up at all it does tend to sit a bit high on the suspension on the last side raised.
- andysat
- Zed Five
Leaking adaptive suspension?
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
- Smartbear
I'd have thought it's the spring that governs ride height, not the damper?
e85 3.0si sold
- Zed Five
I'd agree, but if all else looks in order, worth a check.
- sunnydays
Thank you for the suggestions everyone much appreciated.
I get the car back tommorow with the new springs and will remeasure up, have had a conversation with the mechanic saying everything looks fine to him.
Will measure when i get back etc...
Thanks guys
Thanks guys
- ronk
Did you find the answer?
- sunnydays
- ronk
Nice when a plan comes together !
