brake piston rewind tool
- Pastry
I want to change the rear pads on my E89 but because of the electronic handbrake (poxy idea that was) you need a rewind tool for the piston? Has anyone bought a cheap one that worked on their E89 please?
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Now gone:
- Smartbear
You don't need a tool, the motor part comes off & you can wind the Pistons back manually
e85 3.0si sold
- Pastry
Are you sure Mr Bear, after taking the callipers of today Stu was sure you needed the tool?Smartbear wrote:You don't need a tool, the motor part comes off & you can wind the Pistons back manually
991 Carrera 2S
Now gone:
Now gone:
- Smartbear
e85 3.0si sold
- cj10jeeper
I have this one and used it on countless different brake set ups
Even those that don't need to be rotated, but just compressed are easy with it
http://www.ebay.co.uk/itm/19pc-Brake-Ca ... Swm8VUrv76
- Smartbear
I believe the e89 rear calliper Pistons need winding in from the back of the calliper after the electric actuator has been removedcj10jeeper wrote:I have this one and used it on countless different brake set ups
e85 3.0si sold
- Pastry
Thanks Guys. I'll have a look at the video but either way it is still cost effective for me to change them myself, especially as the callipers are off waiting to be paintedSmartbear wrote:I believe the e89 rear calliper Pistons need winding in from the back of the calliper after the electric actuator has been removedcj10jeeper wrote:I have this one and used it on countless different brake set ups
991 Carrera 2S
Now gone:
Now gone:
I use long nose pliers on the rear calipers on my MR2, just hold them against the piston and push/turn slowly. That's always worked for me.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I wound my brakes from behind after removing ebrake mainly because I usually strip the whole lot clean repaint etc.
Always think there is the danger of tearing the dust seal if rotated from the piston face.
- benv6
I have changed my rear pads few months ago and used that same video, you can use a screwdriver but I have used the tool mentioned in this thread (ebay one) and it makes it a lot easier. the screwdriver option would take you ages to push back the piston.
- Nictrix
Just to be completely clear on this for when it comes time to change ours, can you wind the piston in both ways?
Either with the e-brake part attached winding the piston or with it removed and winding from the rear?
- Smartbear
I'd say yes, looks like Pastry has left the actuators attached & wound the Piston in from the frontNictrix wrote:Just to be completely clear on this for when it comes time to change ours, can you wind the piston in both ways?
e85 3.0si sold
- Pastry
I used the method shown in the video using a large flat blade screwdriver. With hindsight I would have bought the tool as it's only a few pounds and would make the job a lot easier with much less chance of damaging something.Smartbear wrote:I'd say yes, looks like Pastry has left the actuators attached & wound the Piston in from the frontNictrix wrote:Just to be completely clear on this for when it comes time to change ours, can you wind the piston in both ways?
991 Carrera 2S
Now gone:
Now gone:
- cj10jeeper
For this reason I always buy s tool. Used it in BMW, jeeps & Jags all with different set ups and so much better than messing with screwdrivers and g clampsPastry wrote:I used the method shown in the video using a large flat blade screwdriver. With hindsight I would have bought the tool as it's only a few pounds and would make the job a lot easier with much less chance of damaging something.Smartbear wrote:I'd say yes, looks like Pastry has left the actuators attached & wound the Piston in from the frontNictrix wrote:Just to be completely clear on this for when it comes time to change ours, can you wind the piston in both ways?
- R.E92
This should be possible with ISTA-D.
I have read somewhere else that there is a software procedure for releasing the ebrake.
EDIT: Found it. It's part of ISTA-D, under Vehicle Management >> Service Functions >> Chassis and suspension >> Parking Brake >> Worshop mode > "ABL - Parking brake: Workshop mode"
I think BMW use a special tool for manually retracting it now but before that tool came along they used the above method.
