Dash button problem
tnnytnny
Dash button problem
Post by tnnytnny » Sun Feb 19, 2017 2:25 am
Hi Guys
Anybody else have this problem with what looks like the buttons on the glasses compartment melting?
Nictrix
Dash button problem
Post by Nictrix » Sun Feb 19, 2017 2:55 pm
Not seen that before but it definately looks like something has been put on it that has reacted with it.
A shame as you will see it everytime you are in the car.
Smartbear
Dash button problem
Post by Smartbear » Sun Feb 19, 2017 3:02 pm
Have you got an air freshener in your car? I've heard of them reacting with plastic trim parts-the chemicals must be pretty nasty :(
e85 3.0si sold
tnnytnny
Dash button problem
Post by tnnytnny » Mon Feb 20, 2017 10:20 pm
No air freshner near it . I personally thought it might have been the sun. Anyone know if i can replace the button?
M1ghty_m0use
Dash button problem
Post by M1ghty_m0use » Mon Feb 20, 2017 10:25 pm
My money is on this button is directly under the rear view mirror and some time in the past there been a dangling air freshener . The oils in them can drop and peal plastic coatings , my old mans freelander did the same on his hazard button very common . I never now hang air freshener, I use sprays on the matts and carpet
Dietcokeman
Dash button problem
Post by Dietcokeman » Wed Feb 22, 2017 10:33 pm
It may also be worth checking the rear view mirror isn't leaking ! The auto dim rear view mirrors have a fluid between the two sheets of glass inside them and between the glass is a fluid that is very corrosive , the The mirror is damaged it can leak out and dissolve the dash, it's really nasty fluid . The early E85's suffered with this issue but I've not heard of an E89 doing it, but might be worth checking , if it's leaking, remove the mirror straight away before more damage is done . Excessive heat exposure can cause a leak too . Best check just in case .
Silverzedtom
Dash button problem
Post by Silverzedtom » Wed Feb 22, 2017 11:38 pm
Maybe a drop of petrol on a fingertip after a fill up? Probably a long shot but if it's left for a while it could react I suppose. You'd assume it was done by a lefty if it is from the pump.
E85 2.5si
F55 Cooper S
