Cracking Alloys
Cracking Alloys
Hi all
Driving home last night hit a fairly big pothole front passenger side wheel at 55-60 mph . Made an unpleasant bump
Looking at the wheel it looks fine, no visible damage, and driving into work this morning all feels fine and dandy. However I'm aware from other posts how easy it is to crack the 326's and it sounds as though it's not always easy to spot the crack. Should I be worried?
- jimbo1958
Cracking Alloys
I'd be getting them checked asap. 326's prone to cracking especially on RFT's.
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Jaguar F Type V6s Roadster
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
Cracking Alloys
Ok thanks. I assume if I take it to my BMW dealer and fess up about the pothole it would reduce my chance of a replacement under warranty if it is cracked....?
Cracking Alloys
you have no chance of a warranty replacement
- JustCruzin
Cracking Alloys
If you're unlucky this may be the case, however, I did have a crack spotted on my first ever MOT on a rear 326. It was a tiny 1cm split only visible in the inner face directly adjacent to the tyre. The degree of 'radial distortion' was checked and it was within their acceptable range so the wheel was replaced under warranty.35i-Nut wrote:you have no chance of a warranty replacement
Good luck
Cheers JC
Cracking Alloys
You have had a better experience than me , they are happy to point out the 1 cm cracks , unhappy to replace them under warranty
- Wrs
Cracking Alloys
Me too35i-Nut wrote:You have had a better experience than me , they are happy to point out the 1 cm cracks , unhappy to replace them under warranty
Gone - Black Sapphire Z4 E89 35is
Gone - Midnight Blue Z4 E85 3.0si
Cracking Alloys
If its cracked badly usually your tyre will loose pressure and will be like a slow puncture so if its not id say its fine as you have already been driving on it. Just take the wheel off and check it how long would that tke 15 mins
Cracking Alloys
Thanks all for your replies.
I had it checked and its all fine. But I will be keeping a more careful eye out for potholes....
Cracking Alloys
Welcome to my world. Last time my nearside rear cracked I discovered I had been driving around on a deflated and now damaged rfl tyre. The crack has now been repaired and I have got rid of runflats on the rear. No further problems I now spend my time avoiding Manchesters pot holes. 19 inch Bmw - Ronal wheels are made of chocolate but Bmw will not accept responsabilty for potentionally dangerous alloys for Uk Bmw owners.
Cracking Alloys
Found out one of mine was cracked after the tyre pressure light came on a couple of times, local tyre place identified the crack, found a local metal fabrication company that welds up a lot of wheels, £30.
