Hey folks, been a while!
My oil light dropped a notch below full the other day. Likely 4000 miles since my last oil change a year ago.
Topped up maybe a quarter L, then noticed a day later it hadn't shifted so put a bit more in, thinking maybe I was on the edge of a quarter before or whatever - so maybe put in 0.75 tops which looking back was technically too much.
Anyhoo, next time I could test....still not moved so I've not added more this time.
It's a 20i, so it was 4.5L on last oil change - any ideas why it's not moving? Don't want to add more in case the sensor is telling fibs, but ideally don't want to do a full oil change right now (though it was 12 months ago I guess).
Oil light
- Smartbear
Oil light
Hi, after adding that much oil leave it a couple more days of driving to see if it corrects the level reading, my e85 also suffered a slow to react level sensor, I don't think it's very unusual
e85 3.0si sold
- buzyg
Oil light
Who's daft idea was it to ditch the dip stick. Happily the ///M still has one. In the absence of any other impirical data, I would tend to go with what is in front of me. Ie put oil in untill the reading is correct. Or empty it and refill.
Oil light
Hmm yeh fair point that - it's only been maybe 10 miles since so I'll leave it a few days. Thanks both!
Oil light
I find mine can be a bit of a pain, readings all over the place if only just got up to temp or on the slightest incline. Give it a good run at decent speed, get somewhere flat, have a check
2009 Sapphire Black 23i
- hopz121
Oil light
As others have said, wait a bit before adding more.
Usually they say wait until the car tells you to add a litre before topping up.
So I would have left it as it was personally.
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
Oil light
So the plot thickens...got the garage to drain and oil change while it was in for the MOT, save me a job.
They filled back up and low and behold, my oil level still sits a quarter down the indicator - after a good few drives.
Is there a simple way to check the sensor? Something's not doing what it should...
