Ok go easy here as I am learning but also struggling. The booklet says press the button above the strorage compartment for 3 seconds.......but what button, what storage compartment?
I have pressed the phone button on the wheel and the one of then dash and no entering pairing mode.......hang on, is it revering to buttons in the armrest where CD and nav units are.
New to iPhones as well, but if I have a iPhone 5, do I just get a cradle/ cable from BMW that will allow it to dock/ connect in the armrest, or as this is just for phone and not music am I better off just with the std Bluetooth for that?
I have an iPod Classic with some 700+ albums as well! how would I connect this to the system?
Like I said new to this.
Paring phone with z4m standard fit nab unit.
- cj10jeeper
Re: Paring phone with z4m standard fit nab unit.
The pairing button is inside the centre console, visible when you open the flap.
You need to press that, not the buttons on the steering wheel.
Mark - it’s not the most intuitive system and takes a while/some patience! It took me a few goes the first time for it to connect. Then all worked perfectly. Have bluetooth switched on and pairing screen on the nav then press the button in the console - you don't need a cradle for the phone to work. For your iPod you can use the aux socket with a cable (if you have one) or the intravee option.
Z4M Roadster - Interlargos/Champagne
As I typed I realised there was a storage hole behind me and that the answer was bound to be in there.
iPod uses a cable in the other cars (aux in), so no problems with this, but I assume this means that the playlists/control over the iPod will be lost or is there an iPod connector that allows this function? Or is that the intervee option?
- srhutch
- Moderator
1. Have you definatley got Bluetooth? Just becasue it's on the head unit and MFSW means nothing.
2. Aux was standard in Z4's manufactured in 2007 (maybe late 2006). If you want to keep control of the iPod you need a Dension, Dice or Intravee.
![Image](https://z4-forum.com/images/srhutch_sig.jpg)
All paired, took a few attempts though
Thread revival time. I'm having trouble pairing my phone to the standard Z4M stereo. I press the button on the central storage compartment lid but nothing happens.
I've tried holding it down then turning the ignition on and nothing. Also tried just pressing and holding it with the ignition to position 2 and again nothing. The phone doesn't pick up any devices nearby either.
Is there a chance my car doesn't have bluetooth? On the original spec sheet using VIN decoder it has the following:
644 PREP. FOR. MOB. PH. BLUET. INTERF.
I can't see any options on the stereo for bluetooth. Advice would be much appreciated![Confused :?](./images/smilies/unsure.gif)
Current fleet:
BMW Z4M Roadster
Ferrari 360 Spider
Ford Fiesta 1.0
BMW Z4M Roadster
Ferrari 360 Spider
Ford Fiesta 1.0
- elevensies
