Z4 M54 SparkPlug Removal/Installation with Pics
Re: Z4 M54 SparkPlug Removal/Installation with Pics
You just have to run engine for a few seconds for making it a little warm. Then, removing plugs will be easier.
Thanks for the post and pics. Feel a lot more confident now there is a process to follow. I have a 2005 2.2 litre straight 6 (172ps) version. Not sure if ths ever was sold in the USA. I live in Germany.
Am also going to change the two rear springs but that looks straightforward.
Beautiful car the Z4, i am surprised BMW ever built it. You see, it is not idiot proof like many other sport cars, you have to be a driver to appreciate this car. Thanks BMW.
Thanks ShipKiller for the excellent write up!
One of my ignition coil packs has failed. Your write up and pics has saved me lots both in time at a garage and cost. Brilliant !
Current Z4 SDrive 35i : Just perfect... But fancy a drive in 35is
Previous 3.0SE 2003 Roadster : Pretty quick and great design
Honda VFR 800i : Rapid two wheel transport
Thanks again Shipkiller for another very useful guide! This is the second time I have used one of your guides - the first was to replace my roof hydraulic pump.
- ryushe
Hi Shipkiller, don't know if you still monitor these threads, but I got a question.
I have an '03 3.0i M54 USA model. Reading through this thread (seems like a great guide, can't wait to try it out!) I've gathered the impression that the NGK Iridiums should be fine to use. Specifically these: 'NGK (5464) BKR5EIX-11 Iridium IX Spark Plug'. However, every parts store that has these says they're NOT compatible with my engine. True or false? If true, which ones should I be looking for? Would the 'NGK (3199) BKR6EQUP Multi-Ground Spark Plug' do perhaps?
Appreciate any answer you can give me. Cheers!
'06 E85 Z4 3.0si 6 speed manual - Black metallic w/ champagne interior
Prev BMWs: '04 E85 Z4 Individual 2.5i • '04 E85 Z4 3.0i • '04 E46 M3 • '04 E61 535d • '86 E28 525i • '87 E28 528e
- powerontap
Based on the compatability list, it should be the BKR6EIX 6418. I've looked at other lists and they all come out with the same type.ryushe wrote:I have an '03 3.0i M54 USA model.
http://www.oreillyauto.com/site/c/detai ... &ppt=C0334
Go Topless
- ryushe
Thanks, didn't find that one earlier. Much appreciated!powerontap wrote:Based on the compatability list, it should be the BKR6EIX 6418. I've looked at other lists and they all come out with the same type.
Can someone just confirm that BKR6EIX is the right plug for my 3.0 2003 Z4?
What sort of plugs should I use in my 2007 Z4si coupe? The dealer wants 26USD for each and I believe I could get the functional equivalent for much less at an auto parts store. A source told me NGK LFR6AIX-11 is good. Anyone?
2007 Z4si coupe
Im looking to do this on my Zed in the coming weeks. Does anyone have this post archived? The pictures are no longer available...
Cmaza
Cmaza
So has any of the post in this thread stated the gap size, because that's what I'm looking for
