Z4 M54 SparkPlug Removal/Installation with Pics
jeanpaul01fr
Re: Z4 M54 SparkPlug Removal/Installation with Pics
Post by jeanpaul01fr » Mon Oct 04, 2010 9:15 am
You just have to run engine for a few seconds for making it a little warm. Then, removing plugs will be easier.
Coolruler
Post by Coolruler » Tue Oct 04, 2011 3:39 pm
Thanks for the post and pics. Feel a lot more confident now there is a process to follow. I have a 2005 2.2 litre straight 6 (172ps) version. Not sure if ths ever was sold in the USA. I live in Germany.
Am also going to change the two rear springs but that looks straightforward.
Beautiful car the Z4, i am surprised BMW ever built it. You see, it is not idiot proof like many other sport cars, you have to be a driver to appreciate this car. Thanks BMW.
H9 BJT
Post by H9 BJT » Sat Jun 09, 2012 7:33 am
Thanks ShipKiller for the excellent write up!
One of my ignition coil packs has failed. Your write up and pics has saved me lots both in time at a garage and cost. Brilliant ! :thumbsup:
Current Z4 SDrive 35i : Just perfect... But fancy a drive in 35is
Previous 3.0SE 2003 Roadster : Pretty quick and great design
Honda VFR 800i : Rapid two wheel transport
mwill195
Post by mwill195 » Tue Jun 12, 2012 11:05 pm
Thanks again Shipkiller for another very useful guide! This is the second time I have used one of your guides - the first was to replace my roof hydraulic pump.
ryushe
Post by ryushe » Thu Feb 14, 2013 5:00 am
Hi Shipkiller, don't know if you still monitor these threads, but I got a question.
I have an '03 3.0i M54 USA model. Reading through this thread (seems like a great guide, can't wait to try it out!) I've gathered the impression that the NGK Iridiums should be fine to use. Specifically these: 'NGK (5464) BKR5EIX-11 Iridium IX Spark Plug'. However, every parts store that has these says they're NOT compatible with my engine. True or false? If true, which ones should I be looking for? Would the 'NGK (3199) BKR6EQUP Multi-Ground Spark Plug' do perhaps?
Appreciate any answer you can give me. Cheers!
2003 Sterling Grey BMW Z4 3.0i
powerontap
Post by powerontap » Thu Feb 14, 2013 1:16 pm
ryushe wrote:I have an '03 3.0i M54 USA model.
Based on the compatability list, it should be the BKR6EIX 6418. I've looked at other lists and they all come out with the same type.
http://www.oreillyauto.com/site/c/detai ... &ppt=C0334
Go Topless
ryushe
Post by ryushe » Thu Feb 14, 2013 4:55 pm
powerontap wrote:Based on the compatability list, it should be the BKR6EIX 6418. I've looked at other lists and they all come out with the same type.
Thanks, didn't find that one earlier. Much appreciated!
pharmed
Post by pharmed » Sat Nov 23, 2013 6:01 pm
Can someone just confirm that BKR6EIX is the right plug for my 3.0 2003 Z4?
scott delong
Post by scott delong » Sun Oct 22, 2017 1:57 am
What sort of plugs should I use in my 2007 Z4si coupe? The dealer wants 26USD for each and I believe I could get the functional equivalent for much less at an auto parts store. A source told me NGK LFR6AIX-11 is good. Anyone? :|
2007 Z4si coupe
Who is online
Users browsing this forum: No registered users and 2 guests
