After some weekend diagnostics, I know the following:
Can't find any loose cables to the column or motor.
Greasing of the engine bay components seems to have done nothing.
Fault is happening closer to straight than previously, indicating something is deteriorating.
All of this is leading me to think it is an issue with the electrics in the column or motor. Looking at prices from ECU testing and BBA, seems BBA are cheaper but their reviews on google are not good reading, so perhaps better to spend the bit more!
Any other ideas before I pull the column out this weekend?
EPS failing in specific circumstances
Second hand unit if existing unit is going to cost too much. It would have to be keyed to the ECU .
Not messing about with that, hence going for a rebuild of the current unit.raymond.harper wrote: ↑Tue Aug 22, 2017 9:54 am Second hand unit if existing unit is going to cost too much. It would have to be keyed to the ECU .
EDIT: Realised I misinterpreted what you said! To be honest I'm looking at following yourself and Mat down the hydraulic route, I don't want to take another chance on an unknown second hand column that could break itself in 6 months.
I'm having a similar issue with my 2006 Z4. Did you manage to resolve this?
