window alignment
Tysonwills
window alignment
Post by Tysonwills » Mon Aug 07, 2017 8:12 am
Hi Guys i have just bought my Z4 and am loving it.
I am going through a few things that need to be sorted.
I have the dreaded wind noise on the drivers side and had read on the forum that you could adjust the angles etc from bolts on door base.
I checked and the previous owner had done this and they are all the way closed with no more adjustment, also they had use the trick of spacers in the door rubbers near the top where the window closes.
If you check the images it looks like the window is touching the roof and stopping it going up completely.
They must not have been able to solve the problem, im not that worried about the noise but worried that it could let in water if it gets any worse.
Has anyone got any ideas as to what to do
mac27040
window alignment
Post by mac27040 » Mon Aug 07, 2017 10:11 am
have you tried adjusting the locking mech. on the door, slacken off the bolts and move it slightly further out which would pull the door in and tighten the window to the rubber
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
Tysonwills
window alignment
Post by Tysonwills » Mon Aug 07, 2017 10:12 am
Is it on the door or the latch thats on the frame the door locks into
mj2k
window alignment
Post by mj2k » Mon Aug 07, 2017 8:26 pm
I thought he meant the part on the car frame, but not clear.
Looks like your window needs rotating towards the front of the car, there is other adjustment for the window, but think it requires going in through the door handle after removal IIRC. The bottom of the door has some adjustment, but appears to have been all used.
What is that on your seat??
2016 F82 M4 Comp Pack, Mineral White
2016 F56 JCW - GONE
2007 ZMR, Titanium Silver for sunny days
2012 N18 JCW - GONE
2007 3.0si Z4C, Stratus Grey, Amarone Leather - GONE
2013 520d F10 - GONE
Tysonwills
window alignment
Post by Tysonwills » Mon Aug 07, 2017 11:03 pm
Is it a easy job or would BMW charge a lot for adjusting.
It's a seat cover I recoloured the leather and was using it for protection
Tysonwills
window alignment
Post by Tysonwills » Tue Aug 08, 2017 7:31 am
I have noticed the driver door seems to be slightly raised
could this cause the window to be to high and if so how do I bring it back down
Smartbear
window alignment
Post by Smartbear » Tue Aug 08, 2017 7:34 am
that shut line appears to be rather large? Have you compared it to another car?
e85 3.0si sold
Tysonwills
window alignment
Post by Tysonwills » Tue Aug 08, 2017 8:19 am
compared with the passenger side and does seem a few more mm wider any advice
Smartbear
window alignment
Post by Smartbear » Tue Aug 08, 2017 8:39 am
Tysonwills wrote: Tue Aug 08, 2017 8:19 am compared with the passenger side and does seem a few more mm wider any advice
I would check the other side to see if there's any shims between the door & hinges that may have been left out, has it been accident damaged?
e85 3.0si sold
Tysonwills
window alignment
Post by Tysonwills » Tue Aug 08, 2017 10:16 am
no accident damaged are the shims packing between the door and frame
Tysonwills
window alignment
Post by Tysonwills » Mon Aug 14, 2017 1:31 pm
adjusted the window as much as possible with the points provided.
I have read that you can adjust more by removing the door card and working with it.
Does anyone have directions as how to do this
csquire4
window alignment
Post by csquire4 » Mon Aug 14, 2017 9:19 pm
These will help you remove door card. There is definitely an alignment problem with the glass and/or the door could have sagged.
https://www.youtube.com/watch?v=Oe6GOTybE1U
https://www.youtube.com/watch?v=zqIWUrI2VFE&t=505s
https://www.youtube.com/watch?v=Djgcv-V ... 9rEGt-IUzI
On Friday I discovered I have a window regulator problem so I've been doing a bit of reading about removing door cards and setting up the regulator. There is further adjustment inside the door, it doesn't look easy and probably not for the feint hearted but I might give it a go.
2004 3.0i, manual, toledo blue
Tysonwills
window alignment
Post by Tysonwills » Tue Aug 15, 2017 8:05 am
Thanks csquire4 these vids are great for removing the door card but does anyone know where to adjust the window angle from inside the door once the cards are removed.
