Coupe oil leak but where is it coming from?
- Joycey
The picture with me holding it is a complete seal from BMW. One piece
- Newbers
Joycey - Thanks for the pictures, that helps a few of us. Did you have the oil around the filler cap that can be seen in Buckz picture?
Coupe, KW coil overs, PSB limiters, Powerflex ARB bushes, 18" CSL reps, Aero skirts, ZHP leather knob, Whippy and proud. Probably needs a wash
- Buckz
I've cleaned mine up around the filler cap and it didn't appear again. It must've been overspill from last service.
In the second set you can see where the oil is collecting, under the valvetronic motor which is the same seal that Joycey replaced
- Steve84N
I've managed to buy just the inner bit from BMW, is that the part that leaks or do I need the outer as well?
C63 AMG Estate 6208cc
- Joycey
I didn't get the option to buy it separate. It came as one seal.
- Buckz
The outer from what I can see is just a housing/locator for the motor... So the seal should just pop out of it and new should go in. I couldn't get the whole thing either just the seal/inner part.
- Joycey
Update: So the last few days driving normally has been fine with the new seal, this morning with some quiet roads I had a chance to open her up and now I have oil in the same place, leaking from the under side of the new seal. Going to have a closer look at the weekend.
It looks like its leaking from the bottom of the seal to the rocker cover.
- Buckz
that is dissapointing, it can't be seal then as it's brand new.. you did say that it needs to sit right, I wonder if there's a way to align it properlyJoycey wrote: ↑Tue Aug 08, 2017 11:50 am Update: So the last few days driving normally has been fine with the new seal, this morning with some quiet roads I had a chance to open her up and now I have oil in the same place, leaking from the under side of the new seal. Going to have a closer look at the weekend.
- Joycey
Yeah it has an inner ridge, I'll have another look over the weekend. I did see an American forum mention putting a compound on that rid to help seal better, I wonder if its been an issue before.Buckz wrote: ↑Tue Aug 08, 2017 12:11 pmthat is dissapointing, it can't be seal then as it's brand new.. you did say that it needs to sit right, I wonder if there's a way to align it properlyJoycey wrote: ↑Tue Aug 08, 2017 11:50 am Update: So the last few days driving normally has been fine with the new seal, this morning with some quiet roads I had a chance to open her up and now I have oil in the same place, leaking from the under side of the new seal. Going to have a closer look at the weekend.
- Buckz
cool, let me know how you find it! hopefully I'll get the time to do mine this weekend and report back.Joycey wrote: ↑Tue Aug 08, 2017 3:25 pmYeah it has an inner ridge, I'll have another look over the weekend. I did see an American forum mention putting a compound on that rid to help seal better, I wonder if its been an issue before.Buckz wrote: ↑Tue Aug 08, 2017 12:11 pmthat is dissapointing, it can't be seal then as it's brand new.. you did say that it needs to sit right, I wonder if there's a way to align it properlyJoycey wrote: ↑Tue Aug 08, 2017 11:50 am Update: So the last few days driving normally has been fine with the new seal, this morning with some quiet roads I had a chance to open her up and now I have oil in the same place, leaking from the under side of the new seal. Going to have a closer look at the weekend.
can't find any torque details in the TIS re the seal have you found anything?
- Joycey
Nothing official other than someone stating 9nm so not much at all. I think that's because those little bolts are ally.Buckz wrote: ↑Tue Aug 08, 2017 3:53 pmcool, let me know how you find it! hopefully I'll get the time to do mine this weekend and report back.
- Smartbear
If you still have leaking, check the condition of the ccv as a blocked one will put extra pressure on gaskets due to crankcase pressurisation.
e85 3.0si sold
- Buckz
- Smartbear
You can check it's working by looking at the amount of "pull" needed to open the oil filler cap with the engine running, it shouldn't be much.
You can also see if the inlet is coated in oil by removing the disa & having a peep/wipe around
e85 3.0si sold
- Buckz
Actually there is a way unless I'm looking at the wrong part?
https://vanos-bmw.com/valve-cover-n51-n ... 1127552281
Not to check but to replace (it's a £10 part)
