Can you tell me what part I need please, noticed 2 splits in the pipe work....cars running fine, bit of hesitation on wide open throttle.
Air intake split
- 1000rr
- acer54
Air intake split
Mine was also split there and I had the hose replaced last week, I've added pics of the hose part with part number etc.
- Schematic.JPG (74.91 KiB) Viewed 1050 times
- Part Number.JPG (79.65 KiB) Viewed 1050 times
- Hose.JPG (101.48 KiB) Viewed 1050 times
- 1000rr
Air intake split
Thanks very much
- 1000rr
Air intake split
That part is coming up for the 2.5...mines the 3.0. Are they the same?
- paddy wright
Air intake split
3.0 is different as it has the sound generator hole and a wider neck
http://www.realoem.com/bmw/enUS/showpar ... Id=13_0995
easy to fit.
Air intake split
Mine was gone when i bought mine. Ordered the part for £30. Its fiddly to fit if you have big hands, but only took maybe an hour (that was for me, and im s**t at fixing things that require patience)
- acer54
Air intake split
Agh, Mine is also a 3.0i engine, did not realise they were a different size, I've got the right part fitted, the images I just pulled of the internet to show you the right part - will look more closely at the part numbers next time, sorry about the confusion.
