I had the DSC light + Tire Pressure waring lights on my E86 Z4MC - the Diagnostics software told me it was a CAN failure to comunicate with the Sensor Cluster (Under the Drivers seat).
The one I removed said 'SensorCluster 03' on it and was in a plastic housing. I tried a few used ones that looked the same off eBay that also said SensorCluster 03 but the connectors were slightly different even if the PCB inside was the same. Then I tried this one 'Sensor Cluster 01' that is also off a BMW Mini and it worked!
Result - DSC Lights all off and MOT passed!
I
DSC Sensor Cluster Failure - Fixed
- TrackDriver
- s-l1600.jpg (129.29 KiB) Viewed 1405 times
- Fox889
Nice one! Had the same error lights on my Mini Cooper R50, turned out to be a dodgy wire but this is worth knowing.
2004 3.0 Z4 in Sterling grey metallic
