Anyone know the actual location? My bonnet seems to be lifted in the center but fine on the sides..
There's probably 10-15 travel if I push it down
bonnet catch adjustment?
- Buckz
- Buckz
10-15mm of travel I meant.
- buzyg
Can't see the images from my PC. I have only ever tweaked the adjustment at each side. Not even sure there is one in the centre..
- Bing
Not sure you can adjust the centre latch, but someone on here might know differently. However it could be the bumper out of alignment. When you remove the bumper, if you put it back on and don't push it in as you do up the torx screws you can be left with a panel gap, which may then look like the bumper is not closing properly. If you loosen the screws and then push the bumper forward and tighten them up it may fix the issue.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- Buckz
I wonder, I looked around and I can't see any adjustment in the center. It's not terrible but there's some travel which I do not expect to be there.. maybe I'm overreacting.
- Buckz
You can see the gap in the center, not sure if that's normal.
- 20170705_233407.jpg (197.78 KiB) Viewed 1865 times
- cj10jeeper
iPhone only so can't judge images
If the bonnet is too high you adjust by screwing the loop on the bonnet in after releasing the plastic locking cover.
Corners can be stabilised by screwing the rubber stops in or out. Later models have spring loaded adjusters
If a panel gap then as above adjust the bumper cover torx
do you have the center catch or the 2 outer ones?
