Hi guys is it possible to adjust to he height of the spray on the windscreen on a z4. After cleaning the washer tank and pump filter the jets appear to be a little low on the screen, ok for speeds over 60mph as the forward speed forces the fluid up on the screen but at 30mph they are a bit low. Looking at the jets there doesn't appear to be the little holes that you put a pin in to move the jets. Anyone had to do this at all?
Screen Washer adjustment?
- sharpyboy
2006 Z4 2.5i gap-tech rch+ roof mod + zhp + roof motor now in boot + DLV Exhaust mod
- Mr Tidy
Mine are a bit low on both my BMWs - I just drive faster when I need to use them!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
You sure you got all the gunk out?
I thought the same after I had cleaned mine - cleaning made it a little better, but could do with higher, so asked Indy how to redirect the jets when it next went in.
He had a look and found more gunk in there that I had missed (I do admit I did a very half arsed job), after he cleaned it all out they're more powerful still and get the whole windscreen perfect.
- groovy_hippy
Poke a single strand of copper wire into the nozzle to clean it (copper is softer than the nozzle so it won't damage it). You can sometimes use a pin (carefully!) to redirect the nozzle....
Current ... 2007 Z4 Coupe 3.0si Sport | Manual | Alpine White | Black leather | Piano black dash
Intro to Zeds, now sold... 2007 Z4 2.5i SE Roadster | Manual | Stratus Grey | Red Leather | CDV delete | DLV backbox
