Non-starter
- whenimeetgod
Non-starter
Hi
I used my Zed on Wednesday, 40 miles each way.
I went to start it tonight and wouldn't start. I turn the key to the first click and all the dash lights come on, fan, and all the other associated noises that usually kick in. I turned the key to the start position and nothing, not even the starter relay clicking. There is a very odd sound that comes out of the dash when the key is turned on, a faint double beep which has never been there before. All fuse are ok and the battery has plenty of juice; ideas please
Tony
Tony
- mr wilks
Non-starter
Will it bump start ? ( assuming manual )
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- whenimeetgod
Non-starter
Auto
- mr wilks
Non-starter
OK , What makes you say battery has plenty of juice ?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Number5
Non-starter
Have you tried a set of Jump leads on it ?
If that doesnt work, I'd lightly tap the starter motor with a hammer and see if that gets it turning over.
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- whenimeetgod
Non-starter
Roof comes down & up again, plenty of juice
- Worcester_spoon
Non-starter
Similar thing happened to me recently. Was the ignition switch. Common on z4's apparently so might be same thing for you. I'll see if I can find the part number/info. It's a 10 minute DIY job to change.
03 Z4R 3.0i/Silver/custom quad/330d brake upgrade/LSD/G-Power supercharger/FIC 365cc injectors/Severn Tuning map
- Silverzedtom
- Number5
Non-starter
If it was the ignition switch, the roof wouldn't work (unless its only key position 3 not making contact)
It sounds to me more like the beginning of a dodgy starter motor.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Ducklakeview
Non-starter
Ignition switch is a common failure, and it usually manifests itself as not engaging the starter. 10 mins to swap it.
Mike
Mike
- srhutch
- Moderator
Non-starter
They can fail at different positions. Mine failed intermittently on position 2, so would turn over but not start.
- Worcester_spoon
Non-starter
Assuming mine failed position 3, as everything worked (including roof) but the car wouldn't start (no starter motor, not noise, nothing). I've got a video of it happening somewhere I can post.
Replacing the switch cured it.
- whenimeetgod
Non-starter
Sounds like the switch is the starting place then. Thanks guys
- srhutch
- Moderator
Non-starter
You can get one for around a tenner on eBay, and only a ten minute job to change so a logical starting point.
Mine was from quarry motors via eBay.
- whenimeetgod
Non-starter
Just changed the switch and the same problem. Definitely making a "bing bong" sound it didn't used to. Any further ideas before I get it towed in?
Incidentally, less than 10 minutes to change it indeed
Tony
Tony
