Actual value Eccentric angle VVT (exwnki_u) 173.60 degrees
Setpoint eccentric angle VVT (exwinks_u) 48.80 degrees
Looks like the VVT motor maybe dead as cam position not reaching its setpoint, fuel economy is poor for 2.0 (30mpg best, 22 worst) and some O2/Cat efficiency issues. Looking back at documents someone had the VVT codes reset a year ago, so possibly been putting rich gas on the Cat for a year at least. Concerned for Cat, pretty sure the VVT needs new seals/motor, shame they didnt do that when they changed the rocker gasket.
Does this suggest its a high frequency scan or that its been a problem for a long time?
Error counter: 255
Code: Select all
E R R O R M E M O R Y
Date: 29.05.2017 16:34:31
ECU: MEV9N46L
JobStatus: OK
Variant: MEV9N46L
RESULT: 4 error in error memory!
2A67 CDKDVEST - VVT control
P1050 VVT control (bank 1) - Malfunction or line interruption
Error counter: 255
Logistic counter: 40
1. Environmental condition
Mileage 129360 km
Supply voltage (ub) 12.43 V
Byte-oriented storage for B_vvt in the FF array (bitcnv_vvt) 1.00
Status error Overload VVT1 (stdvovrld) 8.00
Voltage diagnosis port VVT control (uvvtdia) 0.82 V
2. Environmental condition
Mileage 129360 km
Supply voltage (ub) 12.34 V
Voltage diagnosis port VVT control (uvvtdia) 0.90 V
3. Environmental condition
Mileage 129700 km
Supply voltage (ub) 12.25 V
Status Error Overload VVT1 (stdvovrld) 8.00
Voltage diagnosis port VVT control (uvvtdia) 0.92 V
Control error in general
Test conditions fulfilled
Error not present, but already saved
Fault would cause a warning light to light up
Diagnostics active
Cycle flag
MIL
Error code: 2A 67 A8 15 10 50 FF 28 32 88 84 01 08 2A 32 88
83 01 08 2E 32 AA 82 01 08 2F
2A63 CDKDVSTE - VVT control unit monitoring
Error counter: 11
Mileage 129360 km
Duty ratio VVT- Motor control (tvvvtm_u) -96.88%
Mileage 129360 km
Supply voltage (ub) 12.72 V
Duty ratio VVT- motor control (tvvvtm_u) -17.97%
Setpoint eccentric angle VVT (exwinks_u) 173.60 degrees
Mileage 129700 km
Duty ratio VVT- motor control (tvvvtm_u) -98.44%
Setpoint eccentric angle VVT (exwinks_u) 49.60 degrees
Lagereglerueberwachung
Error present, but not yet saved (Debounce phase)
Diagnostics active
Cycle flag
Error code: 2A 63 C4 05 00 00 0B 28 32 88 83 84 D9 3D 32 88
87 E9 D9 D9 32 AA 82 82 D9 3E
2CA2 CDKHSVSA - Heating Lambda probe before Cat (shear stress)
P1100 Lambda probe (bank 1, before catalytic converter) - slow reaction after thrust shutdown p
Error counter: 9
Logistic counter: 39
Mileage 129370 km
Voltage LS heating by cat (uhsv) 0.00 V
LSU voltage vKat (ADC) (uulsuv_u) 2.36 V
Exhaust temp. V. Cat from model (tabgm) 795.00 Grd C
Vehicle speed (vfzg_u) 60.00 km / h
Mileage 129380 km
LSU voltage vKat (ADC) (uulsuv_u) 2.48 V
Exhaust temp. V. Cat from model (tabgm) 800.00 Grd C
Vehicle speed (vfzg_u) 108.00 km / h
Mileage 129700 km
LSU voltage vKat (ADC) (uulsuv_u) 2.30 V
Exhaust temp. V. Cat from model (tabgm) 825.00 Grd C
Vehicle speed (vfzg_u) 106.00 km / h
Too low signal voltage
Error present and already saved
Fault would cause a warning lamp to light up
Error in debounce phase
Error code: 2C A2 E8 20 11 00 09 27 32 89 00 79 A9 3C 32 8A
00 7F AA 6C 32 AA 00 76 AF 6A
29F4 CDKKAT - Catalyst conversion
Error counter: 1
Logistic counter: 32
Mileage 129630 km
Exhaust mass flow filtered (msabg) 20.00 kg / h
Relative air filling (rl) 27.75%
Exhaust temperature Cat. Of model (tikatm) 615.00 Grd C
Lambda actual value vKat (lamsoni_u) 0.94 -
Catalyst efficiency below threshold
Error so far not occurred
Diagnosis stopped
Error code: 29 F4 82 02 00 00 01 20 32 A3 05 25 85 0F FF FF
FF FF FF FF FF FF FF FF FF FF
Looks like the DSC/ABS issue may just be a sensor issue
Code: Select all
Date: 29.05.2017 16:46:08
ECU: DSC_MK60
JobStatus: OK
Variant: DSC_MK60
RESULT: 2 error in error memory!
5E24 Pressure sensor 1/2 implausible
Error counter: 2
Logistic counter: 15
Mileage 129490 km
Vehicle speed 0.00 km / h
Brake light switch 0.00 0/1
Brake fluid switch 0.00 0/1
ASC / DSC_active (pushbutton function) 1.00 0/1
Brake pressure detected 1.00 0/1
ABS control 0.00 0/1
ASC control (BMR) 0.00 0/1
ASC control (AMR) 0.00 0/1
GMR Regulation (GMR) 0.00 0/1
GMR Regulation (MMR) 0.00 0/1
CBC control 0.00 0/1
MSR control 0.00 0/1
TDR regulation 0.00 0/1
SDR control 0.00 0/1
DBC control 0.00 0/1
RTA active 1.00 0/1
Run-Up Mode 0.00 0/1
No suitable error symptom
Test conditions
Error code: 5E 24 A0 02 0F 32 95 00 2A 00 04
5E21 Pressure sensor 2 electrically defective
Error counter: 6
Logistic counter: 17
Mileage 129410 km
Vehicle speed 24.00 km / h
Brake pressure detected 0.00 0/1
RTA active 1.00 0/1
Test conditions
Error code: 5E 21 A0 06 11 32 8D 18 08 00 04
