Ticking . . . Update . . .
Marlon
Post by Marlon » Sat May 20, 2017 10:59 pm
This seems to have got louder recently.
Recorded on phone hanging my arm out of the drivers window after a run with engine warmed up -
https://drive.google.com/file/d/0B2nPpF ... sp=sharing
So whats making the noise, and does it need looking at?
Cars is 2008 3.0si on 55k miles.
Gone: 3.0si 2008 E85
911 997 Carrera S
Chris_D
Ticking . . .
Post by Chris_D » Sat May 20, 2017 11:07 pm
It's a bomb. Obviously.
Yw
:thumbsup:
DPG
Ticking . . .
Post by DPG » Sat May 20, 2017 11:10 pm
HVA's? Does it go when the engine is up to temp?
srhutch
Moderator
Moderator
Ticking . . .
Post by srhutch » Sat May 20, 2017 11:10 pm
Sounds like HVA's to me.
Chris_D
Ticking . . .
Post by Chris_D » Sat May 20, 2017 11:13 pm
Siriusly tho...
Ive had ticking tappety ticking in all of my bimmers from time to time and never had an issue and as soon as id become paranoid about it it then disappeared.
Could be anything from sticky lifters to pernickety valves.
I wouldnt worry unless u have power drop or oil consumption....or an engine seizure :o
Get the obd scanner out colin....
chris6
Ticking . . .
Post by chris6 » Sat May 20, 2017 11:20 pm
Does sound like an HVA problem, not good if it remains , known cold issue usually goes when engine oil up to temp . Has the car had little use lately or stop start moving.
Chris_D
Ticking . . .
Post by Chris_D » Sat May 20, 2017 11:22 pm
....and short commutes can't help Colin.
*taps side of nose*
Marlon
Ticking . . .
Post by Marlon » Sat May 20, 2017 11:22 pm
Its up to temperature on that recording. I've reassured others on here when they post up their ticking engines :lol:
It just sounds louder. Cars running like a dream - sweet as a peach. So Hydraulic Value adjusters - normal noise then.
EDIT:
Has short commutes Mon to Fri, but always gets a long drive at weekends
911 997 Carrera S
Smartbear
Ticking . . .
Post by Smartbear » Sat May 20, 2017 11:24 pm
Hi Colin, sounds a little clattery-is it due fresh oil soon? If it's a noisy lifter your short commute won't be helping much :o
I've never heard of any damage being caused by this though, it just sounds annoying-I'd give it an interim oil change to see if matters improve.
e85 3.0si sold
Marlon
Ticking . . .
Post by Marlon » Sat May 20, 2017 11:26 pm
Smartbear wrote: Sat May 20, 2017 11:24 pm Hi Colin, sounds a little clattery-is it due fresh oil soon? If it's a noisy lifter your short commute won't be helping much :o
Oil change is booked in for Friday - combined with MOT Rob :thumbsup:
911 997 Carrera S
Marlon
Ticking . . .
Thanks for the advice and info. fellas :thumbsup:
911 997 Carrera S
Chris_D
Ticking . . .
Post by Chris_D » Sat May 20, 2017 11:32 pm
Boôked in? Gaaah. Get yerself an oil sucker, diy and save hundreds!
Marlon
Ticking . . .
Post by Marlon » Sat May 20, 2017 11:36 pm
Chris_D wrote: Sat May 20, 2017 11:32 pm Boôked in? Gaaah. Get yerself an oil sucker, diy and save hundreds!
Oil suckers don't work if you havent got a dip stick :P
911 997 Carrera S
Buckz
Ticking . . .
Post by Buckz » Sat May 20, 2017 11:38 pm
It happens on most bmws haha... Simply put valves don't get enough oil on short runs.. go for a decent/proper ride for 30-40 mins and it'll go away, Italian tune up style ;) when I did short drives in my coupe it showed up once.. after a decent drive out it went away and never came back.
Marlon
Ticking . . .
Post by Marlon » Sat May 20, 2017 11:42 pm
Buckz wrote: Sat May 20, 2017 11:38 pm It happens on most bmws haha... Simply put valves don't get enough oil on short runs.. go for a decent/proper ride for 30-40 mins and it'll go away, Italian tune up style ;) when I did short drives in my coupe it showed up once.. after a decent drive out it went away and never came back.
cheers - :driving:
911 997 Carrera S
