Wheels changed...now this??
- Danz4coupe
Put 19" csl's on my coupe and after about 20 mins driving got these dash lights come on!! Have tried resetting the tyre pressure using the button on the centre console but does nothing. I'm guessing it's gotta be something to do with new wheels or could it just be a coincidence? Surely Not??
- 20170514_164200.jpg (61.65 KiB) Viewed 1279 times
- Danz4coupe
Tyre pressures are checked and are 35psi all round.
- Marlon
Could be a wheel sensor knocked during fitting - you need to get a code reader on it
Gone: 3.0si 2008 E85
911 997 Carrera S
- pvr
Best wheel sensor - worst ABS unit.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
When you say it did nothing, how long did you hold it for? It should at least change to red and disappear for a short term if you hold it for a few seconds.
I may be wrong but would expect this after a wheel change due to big differences between sets
When I changed last time this came on immediately, but once reset it never re-appeared.
- pvr
You can try the reset by turning the wheel full lock left to right.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
As above, mine did it when I fitted new wheels. You need to hold the button until the light changes colour and then mine went out on it's own
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Danz4coupe
Lights are always orange including tyre pressure tried lock to lock still the same. Get a beep after 5/10 seconds after too even without moving.
- Danz4coupe
Thought it could be alignment but was fine on 108's
- Stevepj
If it's just the tyre pressure light try resetting it on the move, mine won't reset by following the procedure in the manual, but hold it down for a few seconds when rolling at about 10mph and it resets fine.
So this is where I write about the car? 2003 E85 2.5i, sterling grey, red leather, 106s with Goodyear Eagle F1s, factory xenons, folding mirrors, cup holders, retrofit cruise control, Bilstein B4's all round. And a whippy!
- Danz4coupe
Thanks for the replies...think I need a diagnostic scan to find out for sure. Fingers crossed nothing serious.
Out of interest, what size tyres have you gone for on your 19s?
- vester86
Tyre pressure would give a RED light which turns yellow After pressing the tyre pressure button. These 3 lights are a bigger problem, but as said above you'll need a code reader to see What the actual fault(s) is. Probably something to do with an ABS sensor (educated guess)
- Zed4our
When I change from my summer wheels/tyres to my winter steelie/tyre combo this always happens. I believe its working as it should. You need to reset the tyre pressure sensor by holding various buttons - can't help with Z4 but it is a user setting in the 3 series. I don't think you should be alarmed. Just reset and take for another drive.
- Roundozo
This doesn't look like tyre pressure warning as all 3 lights are illuminated. You need to plug this in before you spend anymore time or money on the issue. As said above, could just be sensor but worst case abs unit. Fingers crossed for a cheap fix.
Past - Z4 Coupe, gone but not forgotten
Present - 530d M sport touring
