Alarm going off after locked
- Tcochrane92
So my Coupés alarm has gone off a few times randomly.
Typical scenario, is drive it somewhere, park, lock, within 5 mins the alarm is going off. No apparent trigger, happens in various places and no pattern
Any ideas what could be causing it?
Battery?
Ta
Battery?
Ta
Current: Imola Red 400bhp 640d & Ocean Blue BMW S1000XR Sport SE
Past: Silver Grey Z4MR, Silver Grey Z4C & Titan Silver Z4 3.0i
Unplug the bonnet opening switch at the bottom of the windscreen and see if it stops.
Replace if so.
Replace if so.
As above, new is less than £15 from BMW. If that doesn't do it then battery is next step to check
- Tcochrane92
Thanks guys, bonnet switch is disconnected. Will check back to see if it gets set off
- kis
Also can be change left in the handbrake / centre console area. I know it sounds silly! Something to do with the internal sensors and getting a reflection thinking theres a presence in the car while its locked...
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Tcochrane92
No change in the centre console area, not rich enough to just have money lying around
Since disconnecting the bonnet switch, the alarm hasn't been triggered yet... so will give it a week and if it doesn't go off again, I'll get a new bonnet switch!
Happy days, sounds like it is that if it was doing it only a few mins after locking and it hasn't since.
- 85genius
I never bothered replacing the switch, all it does us tells you the bonnet is shut, I figured with the size of the bonnet if I don't notice it's not shut I deserve the consequences
Audi quattro driver
NOW SOLD - Ruby Black 3.0 SI Roadster
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
I don't agree, the bonnet can be popped open and held with the release catch only and still activate the sensor, so it's use is really for the alarm. If you don't want bonnet alarm coverage then don't replace and/or code out.
i had same issue and it was the battery giving sensors false readings. i got a top of the line battery after that. previous owner had some tiny cheap small battery in it.
- PhilinZ4
My turn today! Disconnected bonnet switch and it now seems OK...Will pop in to BMW tomorrow to get a replacement
2007 Silver Grey 3.0si
- PhilinZ4
As the stealer wanted just under £38 I think I'll leave it unplugged....
- Ducklakeview
- PhilinZ4
I have just emailed BMW asking them to justify almost £40 for a component that would have moved no more than 500 times in its 10 year life (that's at opening the bonnet once a week)
- Tcochrane92
I bet BMW pay under £1 for that part.
