Yellow traction control light and yellow handbrake light.
Wendy02
Post by Wendy02 » Thu May 04, 2017 6:42 pm
Hello a few days ago I had the yellow traction control light and the yellow handbrake light pop up. The lights are not permanently lit. Lights reset when restarting the car. No stored fault codes. It's going into bmw soon, do I get them to check both the brake pressure sensors then the rear ABS sensors first? I've had the front ABS sensors replaced already and the brake fluid changed.
Wendy
csquire4
Post by csquire4 » Thu May 04, 2017 7:07 pm
BMW diagnostic equipment should pick up the fault. Intermittant fault, I would guess brake pressure sensor. Part is £92 from Ocean BMW (eBay).
2004 3.0i, manual, toledo blue
ESP
Post by ESP » Mon May 08, 2017 11:54 pm
Wendy02 wrote: Thu May 04, 2017 6:42 pm Hello a few days ago I had the yellow traction control light and the yellow handbrake light pop up. The lights are not permanently lit. Lights reset when restarting the car. No stored fault codes. It's going into bmw soon, do I get them to check both the brake pressure sensors then the rear ABS sensors first? I've had the front ABS sensors replaced already and the brake fluid changed.
Wendy
Have you recently had a Flat Battery?
Since i did, then disconnected and replaced my battery i have had the same issue intermittently, plus a Yellow bulb warning and Yellow Flat tire warning. Often comes on 5-10min into a journey.
I have tried and found no errors, other people have tried and not found any. I haven't yet taken it to BMW, i will, but if i knew what the issues was id get it sorted possibly by myself if possible.
Id love to hear what your findings are.
07 Sapphire Black Roadster.
DaveZ4richardson
Post by DaveZ4richardson » Sun May 14, 2017 6:30 pm
Mine is the same. It's also saying brake fluid faulty. Luckily mine still under warranty so going into garage Wednesday.
DaveZ4richardson :thumbsup:
3.0i 2003 E85 auto cruise control, smart top module.
George7
Post by George7 » Sun May 14, 2017 9:31 pm
Hi
Please look at my response to Orange Fault lights earlier in the evening, it will explain why the two lights are on and how to fix
George
X5 30i
530 GT
420 M Sport Plus Grand Coupe-hardon karmon,19" alloys, pro nav, sun roof
Z4 2.5 Roadster, cruise, xenons, sports suspension, red leather, heated seats, heated folding mirrors, aux fitted, 107s, roof motor in boot.
DaveZ4richardson
Post by DaveZ4richardson » Sun May 14, 2017 9:53 pm
George7 wrote: Sun May 14, 2017 9:31 pm Hi
George
Seen it George. It's brake fluid getting replaced this week.
DUG
Post by DUG » Sun May 14, 2017 10:30 pm
George7, I have the same issue, but I don't see your fix. Is it just brake fluid. Might is in getting an oil change etc. and I can get them to change the brake fluid if that will solve it.
DUG
George7
Post by George7 » Mon May 15, 2017 11:09 am
Guys
I think it's a combination of old fluid and the need to bleed the system. The fault with snap on diagnostics machine was very clear what to do and solved the problem. Maybe the sensors and system are too sensitive to both!
George
X5 30i
530 GT
