So I was bored over easter and decided to replace the cam cover gasket to stop a small drip of oil onto the manifold .Straightforward enough and took about 4 hours ,the old gasket was in very poor condition and had become hard like plastic rather than flexible rubber .
A word of caution protect the engine internals to prevent bit of plastic from the gasket entering the engine the old gasket came off in loads of small pieces .
[IMG]http://i1276.photobucket.com/albums/y47 ... 2qm74x.jpg[/IMG]
[IMG]http://i1276.photobucket.com/albums/y47 ... 7xfylm.jpg[/IMG]
[IMG]http://i1276.photobucket.com/albums/y47 ... do9clq.jpg[/IMG]
Cam cover gasket replaced
- alane29
2007 E86 M Coupe
2005 E85 2.5SE
2005 E85 2.5SE
- patriot66
Doing mine tomorrow. Thanks for the tip.
4 hours ! does it take that long or were you being ever so fussy. I did the rocker cover on my sons Astra VXR and after cleaning the very fiddly channel that the gasket sits in, then adding a sealant and refitting, it took about 1 1/2 hours.
Good job by the way
Good job by the way
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Chris_D
Mine came off in bits too although when i came to put the pieces back together to make sure they were all out of the engine I couldnt account for one small piece
Just hope it flew away when i prized it off the 1-2 sparkplug tubes.
Your timing chain looks a bit manky...?
- alane29
4 Hours does seem long but i was being cautious but there is quite a bit to strip off
Not sure about timing chain looking manky i though it all looked pretty clean in there
2007 E86 M Coupe
2005 E85 2.5SE
2005 E85 2.5SE
