Why you not answer my question?
abs light
- enzed4
abs light
It's a bit hard understanding your posts sorry, but I had this problem just a few weeks ago (5DF0 / 5DF1), it was diagnosed as the pump, not the control module, so I had the pump refurbished and it has cleared the dash error lights (and the codes have cleared).
As verster86 mentioned - if you have replaced the control module, it must be coded to match your car - they are vehicle specific so will need coding to your car.
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
abs light
Send the abs pump off to ECU testing in Heanor in Derbyshire.
http://www.ecutesting.com/catalogue/pro ... 16203.html
They will fit improved parts to it. £195 + VAT + removal and fitting labour.
I charge 350 for the whole job, including dropping the abs pump off to them personally and picking it back up.
I have done many..many!
Good luck.
Andy.
Good luck.
Andy.
abs light
we took 3 good modul that work! t he pump whas ok(put 12v stright )
clear the cods.and its came back!
the strange thing,its the same thing evry time with difrent modul and pump
in the morning tern the car. lights came.drive 30 km.after 2-3 h
tern on the car.get out the parking..... and its gon!
- enzed4
abs light
So when you put 12V across the pump, you heard the ABS pump motor activate? If you didn't hear the motor activate, it would be the pump motor that is faulty, usually a stuck brush
Here is a good video of pump motor repair if that is what is faulty (and not the control module).
If you have replaced the control module (and coded it to your car, which you say you have done), and it's also not the pump, then there's nothing really left. Have you tried cleaning the electrical connectors at the plug/socket where the control module connects into the car wiring loom? This has also caused error codes/failure occasionally.
Gone: 2010 35i DCT
