Scary tram-lining on run flasts
- step_change
My Zed is still on runflats. Tram-lining was terrible on the Northbound A1 near Stamford, steering felt wobbly and all over the place. Done 2000 miles now in my Zed and whilst I have noticed the tramlining on some types of road surface it was particularly bad on that bit of road - never been on that bit of road before in the Zed (done it a million times in 5 and 6 series).
Think I need to go for none run flats.
When i get wheels refurbed I may have the tyres swapped over for none run flats.
Gone : 2013 35is, Melbourne Red, DCT, Nav, Comfort pack
Gone: 2007 2.5is, Montego Blue, Auto, Nav
The general consensus of forumers is to ditch the runflats asap. Just make sure you get a good puncture kit in your boot!
You won't look back once they're gone! I have a can of this https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1 in the boot along with an air compressor to get me out of any difficult situations. Have to be careful which tyre repair can you get as not all of them do 18"+ wheels
E85 3.0l i Roadster - Titan Silver
- vester86
Ditch the runflats & check your lower control arm bushes for worn parts
a quick reduction can be achieved using some spacers it dramatically reduced my tramlining by adding 12 at the front and 15 at the rear.
But non runflats are the permanent fix.
Suspension bushes are a big influencer and should you get them changed you really should get a full alignment done at the same time
Lost in space, found in a dustbin........
2005 Z4 2.2
2011 318 d Estate Recalled and repaired - Update: Turbo blown new one about to get fitted....
2008 2.0d Mondeo Estate Gone but not forgotten
2008 TDV6 Discovery 3 HSE
2005 Z4 2.2
Literally changed mine at the weekend, major improvement, no tramlining! Also found tire pressure was crucial in reducing tramlining
2005 e85 z4, 2.5
- Smartbear
That's surprising, mine was more pronounced after I fitted spacers!Nelly Welly wrote:a quick reduction can be achieved using some spacers it dramatically reduced my tramlining by adding 12 at the front and 15 at the rear.
e85 3.0si sold
- step_change
I'd go as far as to say the car is dangerous with the run flats. The car can be wobbly and all over the place on some types of road. Unless this is normal and I am just a wuss...... I have had the car checked and the control arm bushes are fine.
It needs to be ordinary tyres then - I will get them changed when I get the wheels refurbed and buy a spacesaver spare.
I had this too and didnt want to move away from run flats. Ditched the Bridgestone runflats and stuck some new Michelin run flats on and the difference is incredible. Doesnt tramline anymore at all.
2003 Launch car : 3.0 litre E85 in Sterling grey
- Mr Tidy
Thanks for that.Any1else wrote:I had this too and didnt want to move away from run flats. Ditched the Bridgestone runflats and stuck some new Michelin run flats on and the difference is incredible. Doesnt tramline anymore at all.
I like the run-flat idea, and will be needing rear tyres fairly soon and keep having this RFT/non-RFT debate.
Before my Z4C I had a 123d with Pirelli RFTs and they never gave me any problems, so maybe the solution is non-Bridgestone RFTs.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- BSVA
Did the same thing as Any1else and ditched the Bridgestones for the Michelins, difference really is incredible.Any1else wrote:I had this too and didnt want to move away from run flats. Ditched the Bridgestone runflats and stuck some new Michelin run flats on and the difference is incredible. Doesnt tramline anymore at all.
2004 BMW Z4 3.0i, Titanium Silver, Black Leather, Premium Pkg, Sport Pkg, Xenons, Ellipsoids,
Continental ProContact RX SSR's.
- gannet
as one of the first to this one here I can still recommend themBSVA wrote:Did the same thing as Any1else and ditched the Bridgestones for the Michelins, difference really is incredible.Any1else wrote:I had this too and didnt want to move away from run flats. Ditched the Bridgestone runflats and stuck some new Michelin run flats on and the difference is incredible. Doesnt tramline anymore at all.
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
- BSVA
I think we were the only two members that kept the runflats, just changed brands as mentioned. Still loving the Michelins...no problems here.gannet wrote:as one of the first to this one here I can still recommend themBSVA wrote:Did the same thing as Any1else and ditched the Bridgestones for the Michelins, difference really is incredible.Any1else wrote:I had this too and didnt want to move away from run flats. Ditched the Bridgestone runflats and stuck some new Michelin run flats on and the difference is incredible. Doesnt tramline anymore at all.
