Today the zed passed its MOT with just advisories on need to replace tires soon.
The not so good news is this evening the drivers side seat belt will not fit into the "stalk" . Any advise on possibly remedy or how easy it is to replace the stalk, plus where best to source a replacement.
Best regards
Dave and Sarah
Seat belt stalk faulty straight after passing MOT
The stalk? You mean where the seatbelt clips in?
Hi
Thanks for quick responses
Yes, I mean where it plugs in.
Thanks for the link, it does seem a bit involved but doable
I am feeling rather P----d as it worked fine until the MOT tester tested it.
Dave
Dave
- Crazy Harry
I'd go low tech first.
Get a good torch (and magnifying glass) and have a proper look inside and find out why its not going in. Never had a belt buckle fail but my first thoughts are: something in the mechanism; mechanism has moved to lock position and needs pushing back; red button sticking; something in the hole in the clip?
Simple and cheap first!
Hi Crazy Harry,
you are spot on, I got an email this morning from wifey, she confirmed having found a small leather tassel from her red poncho stuffed into the seat belt receiver. She plucked this out with a tooth pick and now all is well.
I feel guilty now for suspecting that it was caused by the MOT tester, also wifey is now being far too cocky.
Dave
Dave
You let your wife drive the car wearing a red poncho, we need photosPeterboroughdave wrote:Hi Crazy Harry,
Dave
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
