Roof on the key
Roof on the key
Hi guys
When I bought my 2.5si facelift the key would lower and raise the roof.
Been on holiday for 3 weeks and this no longer works. Roof is fine from the buttons though.
Any ideas?
Adrian
Any ideas?
Adrian
- markplant
Roof on the key
Did you get a flat battery or was the battery disconnected
- Silverzedtom
Roof on the key
If it raised the roof with the key when you got it someone has added a roof module at some point.
Are you having to hold the roof up/down button on the C console? Most modules will turn this into a 0.5 sec press.
If you are then I'd say the wrap around and clip in style connectors are dodgy (don't know name). As they dont need cutting to fit the module the standard wiring would be ok, hence buttons to drop and raise the top working.
I might be talking rubbish but that's my guess
E85 2.5si
F55 Cooper S
F55 Cooper S
- mr.tourette
Roof on the key
nope..you can program it to operate from the key without a module, the op can get it reprogrammedSilverzedtom wrote:If it raised the roof with the key when you got it someone has added a roof module at some point.
- Silverzedtom
Roof on the key
Talking rubbish it ismr.tourette wrote:nope..you can program it to operate from the key without a module, the op can get it reprogrammedSilverzedtom wrote:If it raised the roof with the key when you got it someone has added a roof module at some point.
E85 2.5si
F55 Cooper S
F55 Cooper S
Roof on the key
There was no flat battery, roof works perfect from inside but not on the key.
- sharpyboy
Roof on the key
What key presses did you have to do to raise and lower the roof from the key?
2006 Z4 2.5i gap-tech rch+ roof mod + zhp + roof motor now in boot + DLV Exhaust mod
- kis
Roof on the key
Normally its hold the "unlock" button. Does the windows too sometimes.
Press and hold "lock" should (or can be programmed) to close windows and close roof...
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- enzed4
Roof on the key
Yep, this is a coding option, rather than a module. I had this enabled on mine (via NCS) before I got the RCH+ module (cause holding that button on the key while waiting for the roof to go up/latch is such a drag....). If you've lost this function it's strange as it's 'burnt' into the control unit when coded - it shouldn't 'disappear' as far as I know.kis wrote:Normally its hold the "unlock" button. Does the windows too sometimes.
I would get the coding read and see if the feature shows as activ or nicht activ.
Or, try the 'disconnect the earth from the battery for at least 15 minutes then reconnect it' trick - this may reset functionality (but you may need to reinitialise the windows).
Gone: 2010 35i DCT
Gone: 2008 2.5Si Sport
- kis
Roof on the key
I think I've done it with Carly app. Really useful!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Smartbear
Roof on the key
But your hardtop never comes off!kis wrote:I think I've done it with Carly app. Really useful!
e85 3.0si sold
Roof on the key
Smartbear wrote:But your hardtop never comes off!kis wrote:I think I've done it with Carly app. Really useful!
Roof on the key
Will give it a go and see what happens
- kis
Roof on the key
I was talking about the windowsSmartbear wrote:But your hardtop never comes off!kis wrote:I think I've done it with Carly app. Really useful!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
Roof on the key
Also coded one touch for windows up and down. That's pretty handy too.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
